rovingtim
However, the interesting upshot of all this is that in playing with the different RAW developers (and comparing crops to Mr Cat's) I have found different RAW developers work differently on the different cameras.
You must have missed my point. Let me say it as simply as I can:You must have missed my thread:
http://forums.dpreview.com/forums/read.asp?forum=1022&message=38561969
Raw Therapee good with E5. Raw Therapee not so good with E3. ACR good with E3. ACR not so good with E5.
Because cameras are apples and oranges, using the same developer at the same setting will necessarily favour one of the cameras. Why is this so hard for you to understand?
You really don't get it, do you? First of all, I've always agreed the E5 has more detail. However, mtf is also a measurement of the effectiveness of the chosen RAW developer with the apple and with the orange (also a measurement of false detail). Change a RAW developer and the numbers will changes. So how is mtf 'incontrovertible'?(rriley clued you in to the MTF50 results using the same lens on the E-3 and E-5. Those tests are incontrovertible proof for the much greater detail that can be obtained from the E-5.)
This is where you simply don't understand what we are talking about.How about applying equal processing?So, it gets interesting. What is equal?
No, the artifacts simply turn into colour shifts, except where it is black and white (where RAW therapee is excellent). That is why msusic's E5 crops are going purple whereas the E3's aren't.Now, here is the problem found with Lightroom (and most other developers): look at the fabric with the leaf pattern closely and you will see artefacts. RawTherapee "amaze" algorithm and Olympus Viewer do not produce such artefacts from the E-5 raw.
You can't judge what you don't understand.This is certainly true if you believe rovingtim's "methodology" is valid.
But it isn't.
What that reveals is how good the 'standard' process is with a given file from a given camera. In order to optimise my files, I have to use different sharpening, levels, noise reduction, etc. depending on the file from the same camera, let alone different cameras.The only valid methodology is to process the files the same way, then compare the results.
I'm sorry, but I'm getting really tired of saying this: I DIDN'T SAY THIS. Are you purposely being thick?Remember that this thread is an argument that the E-5 doesn't deliver as much detail over the E-3.
Indeed. All is nonsense to those who don't understand.The method to "prove" this contention is to use different developers for each file then post-process the E-3 result further.
