I owned a D90 and recently bought a FX 14-24mm f2.8 lense which kind of heavy. Does anyone knows is D90 body made of metal or plastic? Does it structure able to withstand the weight stress of 14-24mm lense when carrying since it weigh approx 1kg?
D O
In the classic shooting position the left hand should be supporting the underside of the lens and the right hand on the right hand grip supporting the body . . . giving equal support and balance to both . . . so the lens is not carrying the weight of the body and the body is not carrying the weight of the lens.
The only real variance to this would be when using a tripod if the body is mounted on the tripod . . . then the body would be supporting the lens . . . but prob not for any great length of time and should not be of issue to either the body or lens . . . although having said that you would not want to do it for extended periods of time as it would put stress on the connection.
Best,
V G
