David SL
You are correct the lens should be concave(divergent), I put the shape in my graphic without really thinking about it.David:
What you are essentially arguing for is a true medium format
digital camera. This will work better than a 35mm digital camera
just as a medium format film camera works better than a 35mm film
camera. Your idea for modifying normal 35mm lenses to cover a
larger format is similar to the old Speed Magny made by Nikon back
in the 1960's to convert F-mount lenses for use on 2.25x3.25 or 4x5
film. The Speed Magny used a relay lens to magnify the 24x36mm
image up to the desired size.
A couple of points:
1) In your proposed system the internal lens would need to have
negative power, just like a teleconverter. You show a positive
lens.
I researched it further, you are absolutely correct. Multiple elements of both convex and concave glass are needed to produce a regular(distortion free) image, thanks for bringing it up.2) A single element teleconverter will produce an absolutely
horrendous image, no matter how well you grind and polish the
surfaces. There is a very good reason that high performance lenses
have multiple elements.
Right again, I researched it and my intuition on the process was incorrect.3) Teleconverters disperse light, they don't concentrate it. Thats
why they cause a loss of system speed: a small image gets dimmer
when you magnify it. Front converters are afocal, so they don't
change the system speed.
I agree with you here, enhancing existing medium format technology might allow a convenient middle ground to be reached as sensors move up to film size.4) A better solution would be to develop a large sensor for
existing medium format cameras. Kodak has already done this with
their ProBack, which has an area of 35x35mm and has 16megapixel
resolution. Existing medium format lenses will work better than
modified 35mm lenses.
Thanks for your corrections.
Dsl
--DSL
