monte12345
The plain fact is the 35mm film doesn't have the the resolution to support more than 6-24 mp depending on the film.
Yes, I too used a magnifier - looked a bit like a microscope - too focus the grain before making a print.I'm not so sure that is a bad thing or mindless. In all my years of darkroom printing I used a "Grain Magnifier" to focus on the grain, ensuring that the enlarger was properly focused. Sharp grain = sharp print.
- when focusing the AF system always, always grabs the grain in the image. It's mindless. The resolution is so much better than the negative that the focusing system does not even notice elements of the image.
My Canon flat bed scanner was hit and miss. I find the macro lens much more reliable, and AF is a dream.Are you suggesting an alternate procedure for film copying that doesn't involve having sharp grain? Why wouldn't the elements of an image be sharp, if the grain is sharp?
That's a great setup. Mine is very similar. I use Negative Lab Pro for color negative conversion.Currently have everything put together with one small part I forgot to order. That is a 62-52mm step down ring so I can mount it to my 55mm f3.5 Micro Nikkor. I have everything put together with a 200mm nodal rail as the base with an added extension to hold a small Promaster LED light mounted to the extension. This will allow me to mount everything on my tripod and scan quickly by feeding slides or film thru the scanner. The big question for me is how to correct the color mask applied for the color negatives.
since you have to invest more, consider this:Currently have everything put together with one small part I forgot to order. That is a 62-52mm step down ring so I can mount it to my 55mm f3.5 Micro Nikkor. I have everything put together with a 200mm nodal rail as the base with an added extension to hold a small Promaster LED light mounted to the extension. This will allow me to mount everything on my tripod and scan quickly by feeding slides or film thru the scanner. The big question for me is how to correct the color mask applied for the color negatives.
This is a 3 month old thread. And I'm sure the OP is long gone.The plain fact is the 35mm film doesn't have the the resolution to support more than 6-24 mp depending on the film.
I tried that on my D850 and did not like the results. The conversion file created in the camera is a fine jpg. I greatly prefer the results of a raw file converted by Negative Lab Pro. During the conversion process NLP can produce a .tif positive file that is much easier to work with in Lightroom Classic.The D850 is on of the few camera bodies that can do color negative reversion in camera. Big advantage when you quick prune imges on digitization: you can see the properly reversed image in LV.
I use a speedlight set to manual, full or fractional power, with the Nikon ES-2 adapter so I can use a smaller aperture and don't have to worry about vibration, camera shake, or color temperature.Currently have everything put together with one small part I forgot to order. That is a 62-52mm step down ring so I can mount it to my 55mm f3.5 Micro Nikkor. I have everything put together with a 200mm nodal rail as the base with an added extension to hold a small Promaster LED light mounted to the extension. This will allow me to mount everything on my tripod and scan quickly by feeding slides or film thru the scanner. The big question for me is how to correct the color mask applied for the color negatives.
