Thom Hogan
The answer isn't as obvious as many want it to be.This has probably been done to death since the Z6ii came out, but I'm struggling to find the best answer...
I'm a part-time pro that mainly does events. I still have my trusty D750 that I'm about to chop in for a Z6iii.
Now, the Z6ii/iii has dual slots of course, and everyone says that there's no point messing around with ancient SD cards as the CFe is so much faster etc. Which I get. But from what I understand, if you use the SD card in backup mode, the speed will be limited to the slowest card.
First a couple of facts: (1) there is no SD card as fast as CFe cards now are; (2) yes, the camera is "only as fast as the slowest card"; and (3) SD cards come in a lot of different "flavors."
Let's work backwards.
#3 — Use only UHS II cards, and Video Class 3 and as close to 300Mbps as possible. This is basically the fastest type card the current Nikon bodies can use. You limit #2 by this.
#2 — "only as fast" is unfortunately a generalization that isn't clear. If you take one image at a time (no continuous Release Mode), you're not likely to ever see a "slow" card slowing down the camera (though I'll have more to say about that in a bit). If you use Continuous High Extended at top speed, you're likely to see something happen: the buffer will be smaller. That's particularly true if you're using NEF and Backup as your choices. It's less true if you're using NEF+JPEG with each going to a different slot.
#1 — Where I see most people getting into trouble is they say "hey, I have some SD cards, I'll just use those." But that card is UHS I, or worse, not even UHS. It's probably 95Mbps top speed or slower.
Thom's Axiom #237 is "always buy new, top end cards with a new camera. Retire your old cards." First, memory cards don't last forever. The chances of a card error ruining an image rises as the card ages out in its NAND cells. Memory cards can be read almost forever, but they can't be written to past a certain number of cell writes.
Now, as to slowing down a camera. There's a silly little aspect that comes into play: size of card. Whenever the camera needs to access the card, such as when you press the playback button, it does an assessment of the FAT/directory status. The bigger the card, the longer that takes. It's not as big a problem today with faster cards, but in the D500/D850 era it was very common to see someone put a 64GB card in the XQD slot and a 512GB card in the SD slot. The camera needs to check 64GB+512GB before it starts displaying something. Take the SD card out, and playback seems inherently faster.
This is less true now with the faster cards, but it still applies. I wouldn't be using a smaller but fastest CFe card coupled with a 1TB+ SD card, for instance.
