Oops.
I really mistyped (is that the same as misspeaking - only while keyboarding?).
I didn't mean the actual Sensor Brush (TM). I've read Petteri's write-up and I believe that he's on the right track. I guess I should have said "A brush for the sensor a-la Petteri".
When I first read about the CopperHill and Sensor Brush (TM) methods, I felt as if both had good merit. CopperHill for stuff that's really stuck to the sensor, and Sensor Brush (TM) for "normal" use. Personally, I've had dust problems, but never yet anything that was glued to the sensor and required solvent-wiping.
My impressions are similar to Petteri's about the Sensor Brush (TM) products and the Copper Hill method.
The CopperHill method seems like the way to go if you need to remove gunk or “stuck-on” particles, but it seems a bit extreme for just getting dust off.
The Sensor Brush (TM) products sound more reasonable for what you’ll normally need to do. It seems like it should be safer and a lot less work.
It appears that the Sensor Brush (TM) folks are on to a good method of getting dust loose from the sensor and it appears that they've thought about the various pitfalls of brushes in general, and they've found a brush that works for the purpose.
But I, too, am somewhat disturbed by the lack of any concrete description of what, exactly, they're doing to either manufacture or process their brushes. I'd like to know more than what their website is telling me. This doesn’t mean that they're doing anything wrong or totally BSing us, but their site doesn't convince me that they are really doing anything better than what Petteri describes.
And I’m a cheapskate too. I know the camera was expensive, but I still can’t bring myself to shell out a hundred bucks for a couple of brushes – especially if I feel that I could do as well for a lot less.
But the actual Sensor Brush (TM) may not be a bad product and even though the price is high, if you don’t want to go to the trouble yourself of finding, cleaning, and testing an “off the shelf” brush, it may well be the way to go.
Keep in mind that I’m no expert at all on this whole subject. I started reading this thread precisely because I am searching for an answer to the dust removal problem. I sort of got sidetracked when I read about the use of a Zerostat on the sensor and just felt that I ought to voice my concerns about that procedure.
In short, I really do like what Petteri has described and I’m going to try his method, I guess.
I'd love to hear more from people who are using or expanding on his technique. I applaud Gabor for his work and for sharing it with us all. I really do think everyone deserves a good answer to the whole dust-on-the sensor problem.
Jim H.
Jim H.
Why? Why do you think a Sensor Brush (TM) is any better than whatI'm leaning toward a sensorbrush at this point.
Petteri describes?
