Hi.
Please read my post in followup to Gabor.
People have odd ideas about static damage and grounding.
What does static do to blow up an IC? Well, on a microscopic level, it can actually "blow up" parts of the IC. If you look at a static damaged IC under an electron microscope, you'll often see small areas that look like they've been hit by lightning. There will be little balls of melted metal and black stuff all around the area. Just very tiny
On the other hand, you can have more insideous damage that is not visible at all because some of the characteristics of the semiconductor or insulating materials in the IC have been altered slightly.
ICs and PC boards are static damaged primarily by allowing the IC or board to become the path through which a static charge is conducted. Read that sentence again, please.
Here's an example of how to blow up a PC board.
Pick up the board and walk around the room with it or maybe just get up off of a plastic covered seat. Now reach out and hand that board to someone else. There, you've done it!
You are very likely to have a different
relative charge on your body than the other person. The capacitances of your bodies are not large, but large enough to store a reasonable charge. As you hand the board to the other person, the voltage
difference between your body and theirs will try to equalize itself. Since you're handing the board to them, there will be an instant, just as the board touches their hand, when the best path for that charge to take will be through that PC board.
If they happen to touch a ground trace or metal bracket of the board first, and if you're touching that same ground trace or metal bracket, then more than likely no damage will occur. But if the places where you're both touching the board ends up putting one of the ICs in the path of the current pulse, then you've just ruined or damaged some of the components on that board.
So the moral of the story is that you NEVER hand a bare PC board to someone. Instead, either touch that person first to let your charges equalize and then, while "holding hands" pass the board between you. Or, set the board down on a safe, non-conductive, non static surface, and then just let them pick it up. Thus avoiding making the PC board the path through which your charges must equalize.
Notice that I didn't say ANYTHING about grounding anything here. Ground is a relative term. You need to think in terms of relative voltages when considering how static may damage something. And you need to consider what the current path will be if two differently charged objects come into contact with each another. Just don't let that path be through anything sensitive.
Of course, if you're carrying a PC board around and then touch it to something that's "grounded" you'll be using the board as the path through which your chage will equalize with "ground" so that's just as bad as handing to to someone. Again, you need to "hold hands" with the grounded object before touching the PC board to it so that you know that the board won't be the path for the discharge. This is the concept behind using a "ground strap" when working on an electronic device. You're just assuring that you are at the same relative potential as the device.
You don't need to ground yourself or the camera when handling it normally for two reasons.
First, who cares if you or the camera is "grounded"? The main thing is for you and the camera and the lens to all be at the same potential. Be that ground or be that at a million volts. You just want to all be the same. And if you're holding the body and the lens, then you've already brought all three of you to the same potential, so no problem!
Second, the camera and lens are built such that their bodies enclose the sensitive ICs within a conductive shell or "Faraday Cage". That metal or conductive cage provides a better path for any discharge than through the enclosed electronics.
You don't see any exposed electrical contacts anywhere that are not protected in some way. I'd be willing to bet that the contacts that connect the body to the lens all have static protection implemented on both the lens and camera sides. But even without that, by the time those contacts mate up, the mount of the lens has already come into contact with the mount on the camera body so any difference in potential has discharged through that robust, metal path.
Now if someone else was holding the camera body and you came up to them and decided to point your finger at the lens connection contacts in the mount, and you got a bit too close, and the potential between your body and theirs discharged through one or more of those contacts. I'd be very worried that the body may be damaged. But when would that happen?
That's why I just hate it when I'm holding a PC board and someone comes up to me and decides that they need to point to something on the board while we're talking about it. I always pull away and then if they want to point to something, I set the board down and have them pick it up and then point all they want.
Really, if you want to be safe, you should practice these same rules when handing an elecronic device of any kind to someone or when setting it on a condictive surface. Even with the faraday cage, why tempt fate?
The cameras and lenses are designed to be used in the real world. You can relax only because someone else was looking out for you when they designed them. I don't worry about my equipment much. But I won't be Zerostating my exposed sensor either.
Jim H.
You are just WAY too paranoid! If what you say has ANY truth, then
you better attach a ground strap to your camera and never carry it
anywhere! There are deadly static charges waiting to jump from your
finger tips to your sensor and kill your camera! Beware!
Enjoy life. Enjoy the camera. It isn't that fragile.
