blue_skies
Reading some of the remarks - no, I don't think that you are trolling, you do raise some good and serious issues.
Sony cameras do have poor AWB selection indoors, probably poorer than some of the other brands, but generally, none seem to be 'perfect' for indoors.
But you need neither a gray card nor a custom white balance settings.
Gray card are an aid when you shoot RAW - it is sometimes hard to figure out what the white balance needs to be in post, and a gray card is just a quick setup to get you there. If you don't shoot RAW, grey cards can be used in JPG as well.
Most PP tools (I am using DxO and LR3) have an auto-white-balance feature that works remarkably well. It is one way to 'correct', but it does often make indoor pics look too cool. Then you have to add back in some warmth.
Custom white balances? I never needed them - Tungsten, Incandescent, Neon lighting are sufficient to cover most indoor conditions. And Auto works fine if the light levels are ABOVE a certain level.
As to pictures on this forum - I think a lot of pictures are OOC and not processed in post. It is actually preferred - we can see what the camera does rather than someone's workflow - but it does highlight the artifacts as well.
I think that anyone with the 'yellow' pictures will eventually figure out how to get them to look more realistic. Generally, I think that Sony is choosing correctly in keeping the images on the warm side, rather than on the cool side, they are more pleasing.
But I also think that images are taken with less light than 'typical' indoor lighting represents - this causes a color shift to yellow all by itself. If too dark, I wonder if AWB can actually compensate.
Another thing I recommend users is to use the bounce flash to 'fill in' the background - it gives quite pleasing effects - but you have to shoot with flash. AWB with flash is fine - but you have to dial back the flash intensity under most indoors (white ceiling) conditions to get the proper balance of color and warmth.
STILL - I think that you raise a valid point and there is no reason why Sony cameras perform so poorly - lowlight indoors is a very common condition for all of us.
Henry
--I don't complain too much about problems with the NEX cameras because overall I think they're pretty good but Sony needs to do something about the indoor white balance issue.
The NEX cameras are the wost I've seen and pictures posted on this forum prove the point.
It's terrible to have to set a custom white balance (and hope for the best) every time you take a picture with incandescent lighting.
Shooting raw is only a band-aid and not the answer, because most modern day cameras get the white balance very close.
What's really amazing is that many people, posting to this forum, seem to be proud of their yellow pictures.
Henry
