I don't think this is true. Film went all the way from Minox up to 10x8 inches or even larger. There are no large format digital cameras for general photography, and even the so-called "medium format" sensors are barely larger than 35mm.The amount of light in an image is determined by three things - the luminance of the scene, the size of the aperture and the angle of view. As you expand the angle of view the amount of light projected onto the image plane increases. This is inconvenient when you have a sensitive medium that requires a given amount of light, since it means that you have to reset the camera as the angle of view changes. Therefore it has become customary to express the aperture diameter in terms of the angle of view when it comes to labelling settings, though we use the focal length of the lens as a proxy for angle of view. So, rather than setting the aperture in millimetres, we set it as a fraction of the focal length. As an example, if we had a 50mm lens and wanted an aperture of 25mm, we would choose a setting of f/2, where 'f' stands for the focal length, in this case 50mm.
This convention has served photography well for many years but with the advent of digital has been somewhat abused by the manufacturers for marketing reasons. In the digital world we have a much greater variety of active frame sizes in the mass market than with film, which was constrained by availability of processing services in a way that digital isn't.
Aren't f numbers an "equivalent" scale ? I haven't seen any current lens with apertures marked in mm or inches.The manufacturers like to express their focal lengths in equivalents but then fail to do the same for the aperture.
Yes, it would be best to stop talking about "equivalent focal lengths". It confuses everyone. The angle of view of a lens should be shown as, for example, 45 degrees on a 36mm wide sensor. (Or use diagonals as for TV screens.) The true focal length should be given too.So, to take the example above, a 35mm camera with a 50mm lens gives an angle of view of 46.8 degrees. A lens described as 'f/2' will have a value of 'f' of 50mm, giving an aperture of 25mm. Now if we compare with a 1/2.4" camera. A lens giving the same angle of view, 46.8 degrees, which would be described by the manufacturer as '50mm equivalent' or quite often just '50mm' will actually have a focal length of 8.9mm, and if it has an aperture of 'f/2' the 'f' is now 8.9mm, so the aperture is actually 4.5mm. This is clearly confusing, because if the focal length has been expressed as '50mm' then one would expect the aperture to be 25mm, and let in as much light as expected from a 25mm aperture with a 46.8 degree angle of view. In fact, the camera is letting in 1/32nd the amount of light suggested.
Two lenses can have the same angle of view but different focal lengths. For instance, a 150mm lens is "normal" for 5x4 and a 45mm lens is "normal" for 24x36mm.This would not be important except for the fact that it is the amount of light admitted that primarily determines image quality, so many consumers are being conned into thinking that they will get higher image quality than they will in practice.
So, while not for a moment expecting this to happen, I would like to propose a different method of expressing aperture which meets the original objectives of expressing by focal length but is not similarly subject to abuse. I propose that instead of expressing aperture in terms of focal length, we do so directly in terms of the angle of view. Instead of an 'f-number' we have an 'a level'. So, for instance in the cases above the 50mm lens used on FF would be said to have an aperture of a/1.9, where a is the angle of view (diagonal, in degrees) whilst the 1/2.4" camera would be said to have an aperture of a/10.4
Or, they can have the same focal length but different angles of view. A 150mm lens could be designed as a "normal" lens for 5x4, and another 150mm lens could be designed as a long lens for 24x36mm.
A longer lens spreads the light from a given aperture (for instance 12mm diameter) out over a larger area, so the exposure is less. It is the same as moving a projector further from the screen. The point of f numbers is to have a figure on the lens that gives the same exposure regardless of focal length.
