orbmansony
Leading Member
I posted this in the astronomy forum, but have not gotten a response that works.
I am connecting a Canon 7DII to a Canon 2x TC to a T-ring on my telescope. The 7DII will not fire and gives an error message to clean the contacts to the lens.
Last year, I cut out a plastic ring to go over the contacts between the TC and the T-ring in order to get the camera to fire. It worked fine. If I remember correctly, I might have had to put the camera body in LiveView mode one time to get it started firing?
I set up the equipment this past week, and the 7DII would not fire either without the plastic ring, or with the plastic ring between the TC and the T-ring. Pressing the LiveView button has no effect.
But it does fire without an error message if I place the plastic ring over the contact pins in the camera body and between the camera body and the TC. But it could slip out of place as there's no central tube to hold it in place like the TC has.
Not sure why it is different this year, and it would be better if there were a setting in the camera to ignore the lack of pin contact with a lens.
Any suggestions?
Thanks,
Orb . . .
Any suggestions?
Thanks,
Orb . . .
