This may or may not help but I find that the point of max contrast (although as someone corrected me) not max resolution is further forward at f/4 than f/8 at 200mm & 1.2m. If you have not already tried, check out the lens with some 45 degree angle shots of a newspaper. My lens gives acceptable if not stunning pictures at 1.2m/200mm if I stop down and then move backwards slightly to overcome the lens's apparent back focus problem. (Note this back focus is not apparent at f/4 & 1.2m just on stopping down).
Has anyone that has sharpness issues at close distances (1.2-2m or
so) with 180-200mm focal lengths (especially 200mm) tried sending
it in to Canon?
It seems that some claim that stopping down solved the problem (if
i understood), but mine actually gets worse, especially at f7.1. i
get different results at every aperture, none of them pretty. It
generally performs fine elsewhere, at distance, and even close at
lower focal lengths, so i don't believe it's focus or depth of
field.
tests done - setting (no tripod, but equivalent) on steady surface,
mirror lockup, measured distance, AF, IS off, shutter speeds of
1/320 or so, decent light, little if any wind. ( i think the tests
were well enough controlled).
