WilbaW wrote:
letsgofishing wrote:
WilbaW wrote:
The histogram shows that the meter did exactly what it's supposed to do. Congratulations, you have a perfectly functioning camera.
If you want the image darker or lighter than the meter gives you, it's up to you to make that happen. It can't read your mind. Your raw data is fine, and you were able to get the image you wanted from it, so the only problem is that you expected the camera to do something different.
Sorry, I don't believe you're right. The live view of the scene was MUCH lighter than the actual scene - why was this?
Because the meter's job is to make every scene standard bright, with a normal tonal range between black and white. That's what Live View showed you, and that's what you see in the image. It performed faultlessly.
Give the meter a scene darkly and brightly lit and it will make both images look as bright. Try this for yourself - shoot the same scene in daylight and twilight, or lights on and lights off. Unless you hit a limit, like run out of ISO, you'll get the same image brightness. That's the meter doing its job for you.
You can see what the meter did from the histogram for the first JPEG - it's nicely "in the middle", not bunched up at either end. Whereas the histogram for the processed shot is well to the left. You have to tell the camera that you want the histogram pushed to the left if you want it to give you that dark look.
Yes, I could have underexposed by 2-3 stops and then would have got an "actual" result, but why would this be necessary if the metering was supposed to be right iin the first place?
It's because you think the meter can know what
your idea of "right" is, that it should know that you don't want a standard, normal, average, everyday, 18% grey, 50% reflective image brightness. It can't read your mind, you have to tell it what you want.
You just have to accept that the meter is simply giving you a piece of information (a standardised guess of how much light is hitting the scene), and it's your job, not the meter's, to make creative decisions based on that information.
The great thing with digital is that you don't have to rely on the meter and your experience. You just take a test shot and review the histogram, or view the live histogram in Live View, and you know exactly what's going on.
