walter38787
Forum Enthusiast
Walt,
Where can you get WinImages?
Sounds interesting as far as orf files go.
Walter
Walter
--walterAlmost certainly what this indicates is simply that the CamediaI compared tiff, .jpg (1:2.7) and ORF. I found the tiff and jpg
almost identical, including the level of noise. I found the (auto)
processed ORF much better in terms of noise, and identical in
colors, saturation, etc.
software routines to adjust the image are different from the
camera's methods of doing the same tasks. I'd just about bet the
farm that the camera's not doing anything different to get the data
off the sensor depending on what file format the camera has to
create - the basic data is the same, depending almost entirely upon
exposure, ISO setting (because that actually affects the sensor's
acquisition time) and focus.
Just FYI, WinImages' load time for an E10 raw file is 1.09 seconds;So my workflow is: ORF, Camedia (twice as fast as PS since it
converts to 8bit instead of 16), tiff.
load time for an E20 raw file is 1.26 seconds. Testbed is a Dell 1
GHz PIII. On the same machine, Camedia takes over 12 seconds to
load an E10 raw image, and over 16 seconds to load an E20 raw
image.
Exposure affects the actual image off the CCD (in any mode.) TheTo have good results this way, it is imperative to pay attention
when shooting: exposure and especially WB.
rest, because you're depending on Camedia to use the camera's blue
bias, red bias, and color temperature settings to drive the Camedia
software to do something you'll like. Makes perfect sense.
However, if you're not going to use automatic processing, but
instead will be balancing the image by hand, then (a) it won't
matter what WB setting the camera has, and (b) you'll often get far
better looking images. I can demonstrate this easily; here's a raw
file processed automatically by camedia:
Here's the same raw file, processed in WinImages:
As you can see, the E20's auto-white balance and Camedia's
subsequent processing resulted in a visibly yellow image. The
WinImages result, however, is balanced much better (those colors
are definitely much closer to the true colors of the car, paper and
so on.)
I think we can be certain that the noise issue is a processingAdvantages: ORF is smaller than tiff, writes faster to the card,
lowest noise possible with my E-10, reasonable time spent
processing.
issue. A raw, unprocessed image has just as much (or more)
potential to be low noise.
WinImages can batch both E10 and E20 RAW files. And there are manyWhat I would really like is:
1. Some sort of Camedia with batch processing. I suspect this was
left out deliberately, Camedia can batch convert from tiff to jpg
and back ;-(
reasons you might want to do that, for instance to convert the RAW
files to PNG or TRM, both formats that offer lossless compression
that will give you much smaller files than TIFF will.
The base noise in the image is the same between TIFF and RAW, Ibut most cameras exhibit the same noise in RAW and camera
tiff, except the E-10 (and maybe the E-20).
think. There's just no reason for it to be otherwise, and every
reason for it to be just this way. However, the TIFF has been
processed by the camera, and an adjusted RAW file has been
processed by the Camedia software, which is almost certainly doing
something about the noise that is different than the camera.
Olympus is certainly aware that sensor noise has been a consumer
issue since the day the E10 hit the streets, and there's every
reason to think that Camedia is doing something about it.
Exactly my point.And most users' gripe about the E-x0 is the noise ;-(
Walt
Software Engineer
Black Belt Systems
http://www.blackbeltsystems.com/
