Pekka Saarinen
A great test scheme:
http://www.hkdotcom.net/Francis%20Photography%20channel/AF_Test/index.htm
I can produce extremely sharp shots with 10D, but there has been problems in that area, too. Last week I managed to see some patterns in where problems occurred and the test mentioned above showed the issue very clearly. Now I know for sure why sometimes the good focus was lost.
Test results were:
My 70-200/2.8L is sharp on 200mm and 140mm, on 100mm it starts to drift towards backfocus and 70mm is way off back. This correlates well with results of last portrait session I did with 70-200.
My 50/1.4 is front focusing. Clearly.
My 35/2 is backfocusing heavily and when you go further back it focuses all over - looks like the old non-USM motor is not so accurate any more with 10D.
Sigma 20mm is very good (!).
Sigma 14mm front focuses. Not a big issue because I use if mostly over 5.6.
Those test files are in http://www.exhibitserver.com/10D/ should you not take my word for it (I use another server of mine so I would not stress this one). I did also another real life outdoor test session and it confirmed the results above.
I really don't care if these problems are 10D's problem or lens problems and I don't take this personally or as "all 10D's are defective". I will take the whole lot to Canon and let them fix it all to specs, that's it. It's not a big deal - maybe costs some but I'll gradly pay for knowing that my equipment works reliably. If the problem is in 10D then it is clearly paid under warranty.
Pekka
http://photography-on-the.net
Test results were:
Pekka
