While I had a couple of minutes, I quickly compared my copies of the D60 and 10D in the following setup: Indoors, Halogen lighting, ISO 800, 70-200 f2.8 set in Av mode at 2.8 on a tripod with mirror lockup approximately 2m away. Performed 2 shots with each camera in single-focus mode, the first from infinity the second from nearest.
Initial observations: 10D lighting fast and positive focus lock. D60 hunted from infinity but locked on. From nearest focus seting, D60 locked right on.
Results: 10D Inf - rear focused, 10D Near - rear focused.
D60 Inf - rear focused. D60 Near - focused precisely.
Granted this was one test at one focal length and perhaps increasing the "n" and varying the focal lengths will change the results. It is reassuring to note that the D60 images were sharper albeit noisier as well.
A great test scheme:
http://www.hkdotcom.net/Francis%20Photography%20channel/AF_Test/index.htm
I can produce extremely sharp shots with 10D, but there has been
problems in that area, too. Last week I managed to see some
patterns in where problems occurred and the test mentioned above
showed the issue very clearly. Now I know for sure why sometimes
the good focus was lost.
Test results were:
My 70-200/2.8L is sharp on 200mm and 140mm, on 100mm it starts to
drift towards backfocus and 70mm is way off back. This correlates
well with results of last portrait session I did with 70-200.
My 50/1.4 is front focusing. Clearly.
My 35/2 is backfocusing heavily and when you go further back it
focuses all over - looks like the old non-USM motor is not so
accurate any more with 10D.
Sigma 20mm is very good (!).
Sigma 14mm front focuses. Not a big issue because I use if mostly
over 5.6.
Those test files are in http://www.exhibitserver.com/10D/ should
you not take my word for it (I use another server of mine so I
would not stress this one). I did also another real life outdoor
test session and it confirmed the results above.
I really don't care if these problems are 10D's problem or lens
problems and I don't take this personally or as "all 10D's are
defective". I will take the whole lot to Canon and let them fix it
all to specs, that's it. It's not a big deal - maybe costs some but
I'll gradly pay for knowing that my equipment works reliably. If
the problem is in 10D then it is clearly paid under warranty.
Pekka
http://photography-on-the.net
