10D Back Focus
But regardless, given the subject matter, the apparent working
distance, and the extremely minimal depth of field, that's what you
would expect from any camera. If I were to repeat that test with a
different body, for example a Canon film body if you had one of
those before you switched to digital, you'll find the same results.
Also, repeat the test with a macro lens. That way, you would be
eliminating the minimum focus distance issue.
I think repeating the test on a film body with the same lens will show greater DoF. Remember, the 10D has a 1.6 form factor and a 30mm lens on the 10D would be a "normal" lens and not a wide angle. I think this is what is confusing people they expect the same focus performance as a 35mm camera but the lenses act differently.
Same as you, you seem to be in my opposite side, haha!
Wel, the difference between us that I participate in other threads as well but you restrict yourself to the "10D issues" threads exclusively.
Did I mention there is good 10D in the following link posted before
in one of my reply?
No, I rarely ever see you mention good things about the 10D.
http://www.danielckchan.com
The webmaster ask me whether I've bought the 10D now, unfortunately
I know some photogs bought flawed 10D, my favourite camera won't
let me exchange 10D if only for the AF problem which they know it,
just to protect themselves from taking the responsibility of Canon.
What am I wrong if I'm telling you the truth, with the good and the
bad? I post here not because to please you, right?
Like I said before, you seem to restrict yourself to the "10D issues" threads and you're usually bolstering the negative side or condemning the people who speak well of the 10D.
What I find interesting is the area behind the focus point on the
rug picture is in focus. The same is true of the focus test using
the clearly distinguishable grid lines. In other words, both the
rug test and the gridline test are the same. With this thought in
mind seems like your analysis is not reasonable. Given the rug
picture and gridline picture demonstrate the same back focus I
don't see how you can reasonable conclude the rug test confused the
auto focus sensor. Oh well!
It IS possible that the AF was fooled by a spot of the rug within the AF sensor area which is larger than the small square indicates. All I'm saying is why didn't give the AF a DEFINITE target to lock onto rather than an obscure one? It seems like he wanted the AF to fail rather than give it the best opportunity to succeed.
This was not a macro shot and exceeded the minimum focus distance.
Like I said earlier. Real life shooting is what drew my attention
to the matter.
Would it be possible for you to post some of these images which drew your attention to the problem?
Are you positive about the 2 meter shooting distance? It would seem that shooting at 2 meters at f/4 would yield more depth of field than a mere inch or so. Even shooting from 2 meters at 200mm at f/4 would yield at least an inch of depth of field. The depth of field you are showing is much less than that. What focal length were you shooting at? The 1.2 meter minimum focus distance may not pertain to the focal length you were using!
For all who doubt 10D's have focus problems here is a photo to
view. Since I dont have all of the fancy technical equipment that
Canon has I set up a very simple focus test.
The image was shot with the 10D mounted on a tripod and at 45
degrees. I used a Canon f4L lens. The center of the picture is
immediately to the left of the tip of the pen. I used the center
focal point of the camera only.
The pityful thing about this image is that I just got my camera
back from the Canon New Jersey repair facility. This picture
represents the degree of quality and customer service that Canon is
building into their product. The bottom line is there is no excuse
on Canon's part for selling a $1500 camera body that wont focus,
especially after it undergoes warranty repair at their own facility.
http://www.pbase.com/image/16753690
I'm sorry that it's my fault to make you think like that.
Actually I've no bias in camera brand, since my gears are from various brand. I pay so much attention to 10D because I really want one, being waited since D100, then S2pro and until the 10D which I think I ought to make the plunge, but.... For the CS and NS here, that is my true experience in previous days, and still there are some 10D owners struggling from getting theirs from CS.
exclusively.
in one of my reply?
Go ahead, never look back
Go here and look at the focus test using a sheet with gridlines. The center focus point was not fooled on this test as you suggest and it produced the same results.
You seem to beg to differ with the obvious. I wonder if perhaps you are a Canon employee?
http://forums.dpreview.com/forums/read.asp?forum=1019&message=5129295
Hi Peter Pan -
I am begining to think you are a rocket scientist or a Canon employee. For your edification I measured the gridlines on the sheet I used. The depth of field is one inch. You keep referencing 200mm. Keep in mind due to the size of the CMOS there is a ratio of 1.6 to one that needs to be considered so the effective focal length is 320 mm.
Keep in mind Peter you stated one inch of depth of field and that is what I got.
Instead of seeing the obvious and recognizing that Canon is producing defective cameras and providing ineffective repair service leads me to believe you are a Canon employee.
I already saw that test and you STILL won't show any of your "real world" shots as I've asked for at least a couple of times. Also, you entered this whole thing with an antagonistic attitude like you dared anyone to find fault with anything you did. You seem to refuse any suggestion that opposes your foregone conclusion. As for my status at Canon, you're about the 5th person to accuse me of that. I guess it's just standard procedure to try to the discredit angle.
Instead of trying to work with people who are trying to help you with your problem, you are dead set on blasting Canon, their products, and their service. So, using your own logic, you MUST work for Nikon or Fuji.
I dared to find fault. It almost sounds like your purpose is to find fault. That is why I believe you work for Canon. What I find interesting is that in your last reply you did not deny working for Canon!
I will post an example per your request. It may be later tonight or tomorrow. Stay tuned. I will leave the EXIF data intact and post the original image unretouched.
As far as a foregone conclusion is concerned you fail to recognize I did three controlled focus tests all of which showed back focus. The conclusion is foregone per the tests.
Why do you keep trying to find fault?
angle.
No, I am someone who bought a 10D with expectations only to learn the camera is defective. I sent it for repairs once and it came back defective. What is up with Canon! Why are so many people having problems with focus?
As far as the camera goes it is remarkable. If you look at the focus test you can see the fibers in the paper. I shot upwards of 800 images and the exposures were right on the mark, resolution outstanding, etc. Hell, the pictures had a wondeful filmlike quality. All that Canon has put into the 10D does not matter though if it won't focus accurately and/or if they can't fix it correctly. I am not happy about buying a camera body I can't use. I am not happy about spending a small fortune on shipping and insurance back and forth to Canon. I am not happy about the downtime. Most importantly, I am not happy about Canon keeping quiet on the issue and voiding the obvious.
I am a consumer and I don't like being screwed out of my money.
Yes, I am unhappy about all of this.
Film? I don't need no stinking film!
Dan wrote:
"... The depth of field is one inch. You keep referencing
length is 320 mm...."
Dan, that not really true.
That 1.6-1 ratio that you refer to, is a crop factor, not a focal length muliplier.
The image focuses through the lens, and on the sensor in the exactly same size, and with the exact same DOF, as it would if that lens was mounted to a 35mm camera, or a digital with a full size sensor.
There is great deal of confusion being caused with the focal length of lenses mounted to the 10D camera.
Most of this confusion is caused by well intentioned people telling folks to multiply the lenses focal length by 1.6 to get that lenses, "effective focal length".
The focal length of the lens doesn't change, the sensor beinging 38% smaller than a 35mm frame, the sensor only captures the center portion of what would be a 35mm image.
When this smaller image is viewed, it appears to have been shot with a longer lens.
After reading several threads regarding this issue...I couldn't resist....The first thing I did was test the autofocus at macro distances on my 28-135 IS and cheap 28-200.
Conclusion? Perfect AF in almost all cases. I did my best to fool the system by selecting a couple of low contrast subjects, etc...most of the time AF was still right on.
This is my first SLR (let alone DSLR) so I am undeniably an amateur here. I am just starting to get my mind around DOF, etc (thanks to many of the posters here). Bottom line? If its a piece of cake for ME, then the camera must be working....#:>
Don't take my word for it....several of the pictures posted in the canon SLR forum speak for themselves.
Anyway Dan...I'm sorry if your camera doesn't seem to work for you. I am extrememly satisfied with mine. And I sincerely hope that anyone reading these AF threads and thinking about buying a 10D take in to consideration that there are more than a few of us here who's 10Ds worked just fine...right out of the box!
Thank you for the clarification, which makes sense and stands to reason.
length muliplier.
sensor.
with a longer lens.
Try the test discussed here:
http://forums.dpreview.com/forums/read.asp?forum=1019&message=5081290
I personally don't see any problem with the results of your focus test. To me, it certainly seems to be within tolerance of a zoom lens at very close focus distance. But I do think you might put your mind at ease with the test linked above. It' a much more controlled test. Who knows, maybe with your rug test, the autofocus was indeed fine but it got fooled just a tad. I think that if you had focused on the pen instead of the rug, you might not have had an issue. That's just good autofocus technique. Autofocus systems aren't very smart. They're good, but not fool-proof. Do the focus test above, preferably at adequate focus distance or with a macro lens for shorter focus distance.
repeat the tests with different framing..
1) have the close subject on top half of the frame instead of the bottom
2) tilt your test pattern or camera 90 degrees and try again.
3) from 1), tilt your test pattern or camera 90 degrees the other way
if in all instance it focuses too far back, then it probably is a back focus problem, else it could be the AF sensor is not aligned in the center of the frame.
4) try AF focusing from both front and back.
I also seem to have similar back-focuse problem with my 10D. However for me I can acutally see in the view finder that the image is not quite focused/sharp after the camera finishes auto focusing (i.e. the focus confirmation led is lit). But I remember reading the posts of people who reported focusing problem saying that things look sharp in the view finder but not so on when view the actual image. Anyway, here are some my test shots using the (now ubiquitous) focus test chart.
chart position in a 45 degree incline (cropped to reduce size)
http://www.pbase.com/image/16831161/original
chart positioned straight up (parrell to the lens), shot with auto focus.
http://www.pbase.com/image/16831498/original
chart positioned straight up (parrell to the lens), manually adjusted focus ring after camera auto-focused
The lens used is 70-200F4, camera mounted on tripod, 2m from subject. I contacted onecall.com for an exchange, however the person that I talked to said that if Canon does't acknowledge that there's a defect, I'll have to pay a 15% restocking fee. So if anyone who doesn't think that the focus issues are real, I can give you the $220 (15%*$1499) if you are willing to exchange your good 10D with mine :)
Edgar
I posted the wrong link for the manual focused image. Here's the correct link:
http://www.pbase.com/image/16831163
Edgar
focus.
10D with mine :)
Edgar
