BeatX
Hello everyone
Im looking for universal zoom for using it exclusively on vacations/holidays/hikes.
Currently there is Tamron 17-70/2.8 on my radar, but before buying it, I thought I'd give Sigma 18-50/2.8 a try.
I heard many times that this lens is very good optically (very sharp etc), and its super compact size and low weight is something what attracts me.
So I rented Sigma 18-50/2.8 and I've needed only half hour of using it, to be 100% sure I'm sending it back
Usually, I'm trying in my reviews to be more precise and detailed, but Sigma 18-50/2.8 optical flaws and optical compromises are so big and obvious, that this time I didn't bother to do more in depth test and comparison against my other lenses.
Anyway, like always I will be brutally honest and as much unbiased as I can - in my opinions and insights.
Below are lab test with all mtf and charts You need:
https://opticallimits.com/fujifilm/sigma-18-50mm-f-2-8-dn-dc-contemporary/
https://www.ephotozine.com/article/sigma-18-50mm-f-2-8-dc-dn-contemporary-rf-fit-lens-review-36921
Sigma 18-50/2.8 build quality is very much ok, although casing is made of plastic - but it makes a very solid impression.
Nothing creaks - whole parts are perfectly fitted and assembled.
Zoom and focus rings turns smoothly, but I think in new Fuji kit lens all three rings turns even smoother and have more premium feel to it.
AF is blazing fast, almost completely silent and very accurate (in AF-S at least)
I didn't do proper AF-C test, so no clue if this lens can keep up with average moving subjects.
Now.. image quality.
First of all, it's really hard to objectively evaluate this lens, because on the one hand its size and weight while maintaining constant f/2.8 aperture for 18-50mm focal range (for aps-c size image circle) is a true miracle of miniaturization.
Really big applause for Sigma for creating such compact lens for aps-c platforms.
But on the other hand, to achieve such low weight and dimensions Sigma made huge optical compromises, which are visible to the naked eye and which are simply unacceptable to me.
Although I guess that for people with a greater tolerance for image quality, Sigma 18-50/2.8 will be absolutely fine
So, this lens is sharp at every aperture (even wide open) - but apart for 50mm focal length - only in the image center.
Frame edges on Sigma 18-50/2.8 at 18mm are so bad that they literally masked huge decentering in my lens copy.
(right side of the image is always much softer than left side)
This alone should make you understand how bad image quality is in the corners - at least for 18mm.
In general, image sharpness @18mm in Sigma 18-50/2.8 is very poor (at least for 40Mpix sensor resolution), period.
But when I've downscaled images to 26Mpix, results were not that much better (check sample images)
Corner sharpness is gradually improving while zooming in, but in my opinion only from 35mm corners are usable (more less XF 35/1.4 level of acutance) and Sigma 18-50/2.8 is finally fully usable @50mm in the entire frame.
CA is big, distortion is big, vignette is big etc.
Not a big deal, but poor corner sharpness basically across the whole zoom range is not caused due to to lens barrel/pincushion distortions - turning off in LR lens optical corrections don't help much.
So, I will not dig in further - You get an idea what are we dealing it with here.
Below I've posted full size sample images from 40Mpix sensor, at lens peak performance @f/5.6
This time however without link to .RAF files, as basically nobody cares in evaluating raw files
Photos are demosaiced in LR with "Enhance" tool, with default settings - only edits I made is to equalize exposure and recover some highlights (LR lens corrections are on)
Some bokeh/rendering test shots:
So, if You get close enough You can get some medicore results with bokeh, but in real use for 18/2.8 combination in normal distances there is hardly any play with bokeh/shallow DOF
Imo images are just flat, dull and boring.
Nothing unexpected - as every single zoom lens is acting like this, but I want to point out it clearly: constant f/2.8 aperture in Sigma 18-50/2.8 is only convenient because of exposure control, where apart from 50/2.8 combination in my eyes, images will come out flat and boring like from every other zoom with variable aperture.
So, who is this lens for?
I don't know to be honest
I guess for someone who wants constant f/2.8 aperture at every cost, and that about it.
Perhaps for some street shooters? But I heard, that for street photo You close aperture to at least f/5.6 anyway.
For low light photography f/2.8 aperture is very so so.
Sigma 18-50/2.8 will give poor results in landscape applications (for big prints at least), so even below average performing Fuji 16-80/4 is more appropriate option due to its greater zoom range and build in IS.
Perhaps Sigma 18-50/2.8 is ok for someone who want to do documentary of every day family life using only one lens?
It is some option, but for such use I would recommend of choosing new Fuji kit lens, which:
- has more useful focal range
- has much better overall IQ between 23-35mm focal ranges
- has internal zoom mechanism (!)
- has zoom ring which turns in same direction as other Fuji zoom lenses
- has dedicated aperture ring
- has WR
- has better build quality (imo)
- has even smaller dimensions and weight
Seriously guys, think twice before You will decide for Sigma 18-50/2.8 over Fujinon 16-50/2.8-4.8
Just as an reminder, here is my review of Fujinon 16-50/2.8-4.8
You can add to Your kit super cheap, super lightweight and compact Chinese MF lens, like TTArtisan 35/1.4 which will be fantastic complement for Fuji new kit lens.
And such combo (XF 16-50/2.8-4.8 + TTArtisan 35/1.4) will give much more creative options and finals results, than Sigma 18-50/2.8 alone for every scenario I can think off.
But maybe there is some sensible use for Sigma 18-50/2.8.. hard to tell.
If someone know such, please - let us know
At the end, because there is fantastic new Fuji kit lens, I don't recommend of buying Sigma 18-50/2.8
It has too many compromises for only one advantage in return: constant f/2.8 aperture.
Imo it's not worth it.. but YMWV.
I'm giving this Sigma 3.5 stars just because it's the world's smallest and lightest APS-C lens with a constant f/2.8 aperture, what is truly jaw dropping (its size and weight)
But that's about it, optically this lens rating should be 2.5 out of 5 stars in my opinion.
I hope this helps
My gallery: https://www.flickr.com/photos/maciej_k/
- has WR
I hope this helps
