BeatX
Hello everyone,
This is my mini review of Fuji new kit lens.
I've bought XF 16-50/2.8-4.8 recently mainly for my future travel/holiday photography (specifically landscape photography) and to document my family life
Handling, size and weight of this little lens combined with my X-H2 is perfect match.
This setup feels lighter than it looks, and is very comfortable to hold for very long time.
This is imho beautiful looking setup, rally joy to use
Anyway, I'll start with the build quality.
To simply put: its outstanding, especially considering it is a kit lens.
Apart from aperture and MF rings (which are plastic), and zoom ring (which is rubberized), its all metal construction super tightly assembled.
Build quality feels basically the same like on XF 33/1.4 and similar - feels very premium.
Lens is WR, has internal zooming!! (zoom ring turns super smoothly), its very small and ultra lightweight.
Overall, when it comes to build quality - zero complains.
Autofocus in this zoom has LM, which is blazing fast, almost completely silent and accurate (at least in AF-S).
I don't trust Fuji AF-C mode at all, so I didn't test this lens AF accuracy in that mode.
What is interesting though, is that it seems that this lens is not that prone to well known Fuji infamous AF-S issue with wide angles lenses, when focusing on infinity.
I would say AF-S, its more-less ok, but far from being 100% reliable.
When shooting at wide angles (for example combination 16mm@f/5.6), I would recommend to check every shot on LCD after taking a photo, or even better - watch AF distance scale indicator on EVF/LCD before taking a shot, to make sure for critical focus.
Image quality, sharpness.
Finally, after I've got my hands on XF 16-50/2.8-4.8, I could do proper sample test shots on 40Mpix sensor, to evaluate lens acutance.
I didn't run very detailed IQ tests for every FL and aperture combination - lets wait for lenstip.com and their detailed lab test with accurate measurements
As a reference lens for wide angle sample shots, I took my Viltrox 13/1.4
My main interest for XF 16-50/2.8-4.8 is 16mm, so in my tests I focus mainly on this focal length.
I can say already, that 23mm and 35mm FL's are very much ok - I didn't noticed any noticable sharpness problems there.
What I can also say already, is that center of the frame is always perfectly sharp in any FL or any aperture.
Problems starts with extreme focal lengths and image corners (as is usual the case with zoom lenses), where corners sharpness are never gets to the level I would call good.
Corner sharpness in XF 16-50/2.8-4.8 on extreme FL is average/okish, and its best at around f/8
For some users such corner sharpness will be good enough, for others not.
Good news is that in this lens center sharpness is so high, that stopping down 16-50/2.8-4.8 to f/8 for better corner sharpness (so where diffraction kicks in) doesn't hurt so much.
At f/8 lens overall acutance become more even across the frame, and I would say it is as good as it gets.
I mean, overall sharpness from new Fuji kit lens should be good for small prints (up to lets say A3 paper size), or for taking snapshots from holidays and watching them on screen without pixel peeping, but frankly I don't really see the overall IQ of this lens meeting standards of more demanding users, unfortunately (I'm one of such users)
This is good lens for hobbyists, but I would not recommend it for serious applications, such as landscape photography for selling big prints, or for pixel peepers
Moving on.. CA is present, but not as pronounced as I would expect, for me its on average level.
Flare resistance, again - average.
For specific combination flare and ghosting can be very visible, but for "normal" use its not a problem.
Vignetting: quite big, super easy to fix in post.
Distortions.. uhh - those are humangous! In matter of fact, Im 100% sure that average corner sharpness is due to distortion software correction.
Bokeh/rendering? boring and flat, nothing to write home about (as expected of course)
Anyways, below are sample images in full resolution from my X-H2, so everyone can judge the image quality for themselves and verify my opinion.
Link to all RAW files (warning, archive weight is around 1GB)
drive.google.com
All below images are developed in LR and demosaiced, using "Enhance" tool, with default Lightroom sharpening and lens profile corrections applied.
Only tweaks I made are in WB or exposure, to even images.
Chromatic aberration test:
Lens flare test:
Above examples, are taken in extreme conditions.. In normal use flare resistance is good, like in sample below:
Bokeh test:
Sharpness test at f/5.6 for typical landscape application to check how lens resolve fine details in scenery in various FL + comparison with Viltrox 13/1.4, Viltrox 27/1.2 and Viltrox 75/1.2
16mm Image corner sharpness test at various apertures.
As a bonus, last image is processed through DXO PureRAW 3 with DeepPRIME XD demosaic engine, and all lens corrections are applied (lens softness: soft)
Did I regret buying this lens? No, but only because I've got stellar Viltrox 13/1.4 for wide angle landscape shots during my trips.
New XF 16-50/2.8-4.8 as a one lens solution is not good enough for any serious application imo.
Did I will get rid of this lens? No, I think no, because for my use this lens seems to be ideal.
Like I said in the beginning.. my use for this zoom is mainly holiday trips, where I think this new kit lens super small weight and size is more important, that ultimate IQ.
Time will tell.
In summary, did I recommend this lens? Absolutely yes, if You are fine with its average corner sharpness.
Sigma 18-50/2.8 has even worst corner sharpness than 16-50/2.8-4.8, same as Tamron 17-70/2.8 (Not to mention about XF 16-80/4 or XF 16-50/2.8)
From my knowledge, at the moment of writing this review every other aps-c or FF system kit lens has maybe as good, or worst overall IQ than new XF 16-50/2.8-4.8
I repeat, kit lens - not premium standard zoom upgrade
But new Fuji kit zoom is for sure smallest and lightest among all aps-c and FF systems, with premium build quality and excellent price (when bought in bundle with camera)
My conclusion: Fujinon XF 16-50/2.8-4.8 R LM WR is all about compromises.
Only question is, if You are willing to accept those compromises or not.
I hope that my review and sample images will help You all to make a decision
X-H2 | Viltrox 13/1.4 | Viltrox 27/1.2 | Viltrox 75/1.2 | Fujinon 16-50/2.8-4.8
My gallery: https://www.flickr.com/photos/maciej_k/
Fujinon_16-50_sample_images.zip
drive.google.com
Lens flare test:
Bokeh test:
Time will tell.
