Canon R5 Mark II - speculated in Q2/2023, specs
Started 1 month ago | Discussions
KKnipser Regular Member • Posts: 233
Hm...
  • New 61MP CMOS BSI sensor
  • Dual DIGIC X processor
  • 30 FPS electronic shutter with tracking / 12 FPS mechanical shutter
  • Same 8-stop IBIS
  • New High Resolution mode similar to pixel shift shooting found on Sony/Fujifilm
  • 2x/4x/8x digital tele-convertor
  • Same Dual Pixel CMOS AF II from EOS R3 and EOS R6 Mark II
  • Internal 8K 60p video recording (8K RAW video spec to be confirmed)
  • Internal 4K 30p/60p/120p video recording (all by oversampling)
  • FHD 240p video recording
  • Focus breathing correction for video
  • New overheat prevention design similar to EOS R6 Mark II, at least 40min for 8K video, and over
  • 60 min for 4K video
  • Dual CFexpress type B card slot
  • Standard HDMI port
  • Dual USB-C port
  • 9.44M-dot EVF
  • New design of vari-angle LCD monitor optimized for video shooting
  • Launch time: 2023 Q2
Sounds like the hot stuff.
https://canoncamerarumors.com/canon-eos-r5-mark-ii-rumored-specs-coming-in-q2-2023/
And Sony with their sad sensor tech still is like 3 years behind the R5 Mark I, with slow-mo 7 FPS and 1/10th of a second sensor readout.
And Nikon seems locked into those lagging Sony sensors as well, so there is little hope for stronger competition from there.
The R5-series really continues to lead their market segment by more than one step.
Canon EOS R5 Canon EOS R6
645D Regular Member • Posts: 326
Re: Canon R5 Mark II - speculated in Q2/2023, specs
Yes, Canon seems take a big leaps with both R8 and R5II, surpassing Sony's in video specs.
Nikon did that with Z9 a year ago, but now dead in water with all Z5/Z6/Z7 models. I was waiting for Z8, but seems it won't show this year.
Muzi
 645D's gear list:645D's gear list
Canon EOS 60D Nikon D5100 Samsung NX200 Panasonic Lumix DMC-GX1 Nikon D7100 +8 more
drsnoopy Senior Member • Posts: 1,216
8
What a combination of wild speculation and wish list! Especially the “8x digital teleconverter” which would give an 0.9Mp image - brilliantly imaginative! Whatever next? AI image engine creates the picture instead of you having to go somewhere and take it yourself?
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Quarkcharmed
Quarkcharmed Senior Member • Posts: 2,713
This is not a video camera. Why an LCD screen 'optimised for video'?
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM
danferrin Contributing Member • Posts: 730
I can’t wait.  Imagine.  The Grand Tetons,  Sunrise, January, four feet of fresh snow on Jackson Lake, prehistoric era, woolly mammoths and other animals from that era.  And I don’t have to crank up the Delorean to get the photos.
My life is a circle of confusion - photography is my meditation.
See my work at http://www.danferrinphotography.com
 danferrin's gear list:danferrin's gear list
Canon EOS 60D Canon EOS 7D Mark II Canon EOS RP Canon EOS R5 Canon EOS R7 +20 more
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
It can be a very good video camera in the right hands. So why not if it does not compromise stills shooting?
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
Quarkcharmed
61Mp, if true, are vastly excessive for video. Landscape, architecture, product photography - yes, but with this many megapixels, the native resolution isn't a good fit for video. If it does 8K, it'll be in the crop mode. Sony A7RV does 8K and 4K in the crop mode.
Anyway I think these little discrepancies suggest the rumour is fake. I'll be very happy if it's not.
Bigger Contributing Member • Posts: 640
Presumably the digital teleconverter would work with the pixel shift to give higher resolution.
I wish Canon would give us something like a 1.3x teleconverter to reduce file size where the 1.6x crop is too much (or unavailable on APSC bodies).
 Bigger's gear list:Bigger's gear list
Canon EOS 5DS R Canon EOS R5 Canon EOS R7
I think 8K standard video would probably be oversampled, since the R5ii is also supposedly getting focus breathing correction. Maybe that's why it needs dual digic processors.
If it gets 8K raw video, that would have to be cropped.
janez Contributing Member • Posts: 620
It is not a big crop having 8K from 61Mp. Extra Mp are also needed for 8K and 4K mode EIS.
 janez's gear list:janez's gear list
Canon EOS 7D Mark II Canon EF-S 17-55mm f/2.8 IS USM Canon Extender EF 2x II Canon Extender EF 1.4x III Canon EF 35mm F2 IS USM +3 more
MarshallG
MarshallG Veteran Member • Posts: 8,951
Really? 8K video is 32MP, so out goes 50% of the pixels.
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
MarshallG
No Zebras for Stills? Pass
Missing the most important feature. I’ll wait for the R5Mark III.   Canon does it in video mode but not in stills mode.  Pure Corporate Evil, I tell you!
Quarkcharmed
I don't think oversampling is related to focus breathing correction. For corrections you need some small additional margins around the image to get some room for distortions. With oversampling you also capture more than you need but you use that to render a smaller scale image (e.g. you capture 6K but render 4K). Or you capture all 61Mp and then downsample to 8K (39Mp).
If "BSI sensor" is true that means Canon is concerned about the image quality/noise dynamic range, not speed, which I assume would require a stacked sensor. Unless it's both BSI and stacked, which is highly unlikely.
So if those specs are any close to reality, then Canon doesn't target videographers with this camera.
Higgins2002
Higgins2002 Contributing Member • Posts: 913
KKnipser wrote:
Hm...
  • Same 8-stop IBIS
  • Dual USB-C port
  • 9.44M-dot EVF
  •  Not likely because Sony is 61
  • The 1DX series have dual processors not the 5 series so R1 specs
  • This is probably R1 specs
 Higgins2002's gear list:Higgins2002's gear list
Canon EOS R5 Canon EOS R7 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +2 more
Quarkcharmed
UHD 8K is 7680 x 4320 and it's 33 Mp, but these dimensions actually require at least a 7680 x 5120 sensor (3:2 aspect ratio) which is 39 Mp.
The R5 uses DCI 8K - 8192 x 4320 which is 35Mp, but the camera has a 8192 x 5464  44.7Mp sensor in 3:2 aspect ratio.
None of that is 32Mp
cfieldgate Regular Member • Posts: 475
How do you work that out? 8K UHD needs 7,680 wide. A full frame camera has. 3:2 aspect ratio (not the 16:9 of UHD), so that is 7,680 x 5,120 or 39.3 MP.
Generally, 8K for Canon is 8,192 x 5,464 or 44.76MP.
 cfieldgate's gear list:cfieldgate's gear list
Canon EOS-1D X Mark II Canon EOS R3 Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM +6 more
That would be no use with moving subjects.
MarshallG
An 8K TV is 7,680 horizontal and 4,320, or about 33 MP. In DCI (usually an anamorphic mode), the horizontal is extended but the vertical is not, so it’s 8192 X 4320 (35 MP). I don’t know where you’re getting the 8192x5464 figure, but it’s not in my R5. For all practical purposes, my opinion is the 8K mode that matters is the 8K UHD mode, or 33MP.
I’m not a serious video shooter, and I don’t understand DCI mode well, but I think it’s used with an anamorphic lens for expanding the horizontal our further in digital cinema, like 21:9 maybe?… but I’ve never done any work like that so I don’t know for certain.
MarshallG
Ok, nerd. You win. Serves me right for multiplying 8x4 and not busting out a slide rule before posting something here.
Seriously, though — you make some excellent posts here and you’re a great teacher.
Quarkcharmed
Which figures are you getting in your R5?? 8192x5464 is the stills (max sensor) resolution.
