Currantos
Hello.
There is a claim of being able to shoot 30fps, which I am sure the camera is capable of.
Which lenses will be able to keep up with that? We know that many lenses can't even cope with A9 rate due to limitations on how fast lens elements move/motors activate, etc.
Even if focus is acquired correctly if the lens is not keeping up with a moving subject the image will be suboptimally focused. I am as excited as everyone about the A1 and the progress it brings. However, it is important to be realistic about what something is on paper and how it behaves in real life.
Even with A9 many lenses were focusing slower than stated rate. Yes, some kept up "technically" in a sense that 20 images per second appeared in camera but the motor did not and real life AF was probably closer to 10-12 so there were no 20 lens adjustments performed. Not saying A9 doesn't focus well or doesn't deliver great results, it does but not every image is "critical focus" because other factors are in play.
Focus acquisition by the sensor is not the same as lens fully focused in correct spot.
There is a strong possibility of the lens being a limiting factor until it is fully confirmed that 30 lens motor actuations per second are being completed with the lens group arriving in a new position 30 times per second.
Thoughts wellcome.
Thoughts wellcome.
