R6 Dual card confusion
Steve_tEkGuY
Leading Member
Canada
Hi folks,
I have 2 cards in my R6
Slot 1 - FAST Card for Video UHS-II
Slot 2 - Slower for Photos only UHS-I
So this is ok I'm able to record on both cards so video on one card and photos on the second but when I play back I can never play back the video files. Its only showing photos.
If I enable Photo/Video with "separate/enable" then the below options grey out and cant pick the faster card for video.
How can I use 2 separate cards but allow playback for both cards.
Record Funct + Card Settings
Disable
Standard
Standard
Photo Record /Play - 2
Video Record /Play - 1
switch to video mode using the mode dial and you'll be able to see the videos
in my experience you should use the fast card for stills such that the camera can clear the buffer fast enough for 12fps shooting. But I find I have to use C-RAW even I'm using the fastest card available on the market. I find no problem for 4K videos even on UHS-I card
Boy can I relate. I noted taking shots the other day although I had the arrow in the Info showing plainly that my Card 1 was my default and one I shoot to first (or so I want to) it decided to place the shots I took to the Card 2 UHS-II card I also have in the camera. How annoying. I'm still trying to wrap my mind around those settings. I simply wanted to make sure that all my shots went 1st to my CF card and ONLY when it's full to start over to the SD card. One of these days I'll figure it out. LOL
Maybe R6 is too new a camera and its firmware is not yet very stable. Especially when switching between videos and stills sometimes it becomes a chaos.
I've encountered all kinds of problems (though minor) just after 3 months of use:
1. IS suddenly stops working, I have to turn off the camera and turn it on again
2. the buffer can't clear fast enough to my UHS-II card suddenly
3. the screen freezes
They happen very rarely. But I've encountered them.
yes that worked - what a pain in the rear - so if I want to show a photo followed by a video I need to constantly rotate the dial - talk about a dumb design
or I move everything to a single card
