I am also interested in this thread. I am looking to buy the D800E and because the place near me didn't have the D800E I order the D800 to test out since we can return if we are not happy with it.I am just wondering which of the D800E and D750 gives better results at 6400 iso (or maybe above that)
Anyone who has real-life experience with both and no just comparison charts and links?
Both will do great in low light, but the D750 is cleaner when comparing in native size. With noise reduction software being as good as it is these days (DxO PL 4 "Deep Prime" NR and Topaz Denoise), you shouldn't need to worry about ISO 6400 with either camera, as long as you expose properly. Underexposed images will be harder to clean up for sure.I am just wondering which of the D800E and D750 gives better results at 6400 iso (or maybe above that)
Look at the camera comparison tool.
The AF in low light is better on the D750 however, so maybe that should also be part of the decision process.
The Nikon D800, D800E and D4 focus down to -2EV, whereas the D750 focuses down to -3EV. The D500 focuses down to -4EV,... so yes, in theory the D750 AF should focus more accurately in low light than the D4, plus you get more pixels on your subject. The D4 has a 16mpx sensor compared to 24mpx in D750. I'm not saying the D4 isn't still a great camera, just saying the D750 low light focusing should be more accurate.I guess the D4 AF is awesome according to many testimonials. It is also a good low light performer which means the AF system has to follow this probably it is thanks to the AF that the camera is a god performer.
But the d800e also has got the same AF module and processor. So the d750 is better than the D4?
I understand you and I am with you. I think it will depend on the quality of the light in the low light situation. Have you tried to download some samples around the web? I don't know if I can refer to another website with additional RAW files. I could re-direct you to that website and you can download the samples. Do you understand what I mean?Of course, you didn't hijack my post.
Thank you very much for your inputs and the important info.
I really struggle to find someone who can give a clear answer to my question.
In my opinion, the D800E is a way better camera than the D750.
The stunning D800E sensor itself is the reason for someone to go for this camera.
But again..I would like to know the real-life differences between these cameras at iso 6400.
Of course the D800 sensor is great, but if we're talking low light high ISO, the D750 has the slight edge over the D800(E). why is that? Because to get higher resolution out of that sensor, Nikon had to cram in a lot more pixels. The more pixels you cram onto a sensor, the less light gets in, the more noise it will produce at any ISO range.I really struggle to find someone who can give a clear answer to my question.
I told you, and I even tried showing you what the difference is with real life examples that you yourself can control. The real life difference is that the D800(E) will produce slightly grainier images at ISO 6400 compared to the D750.The stunning D800E sensor itself is the reason for someone to go for this camera.
Have you had the D800E? Can you give your feedback about using manual focusing lenses with it? How accurate is it?Of course the D800 sensor is great, but if we're talking low light high ISO, the D750 has the slight edge over the D800(E). why is that? Because to get higher resolution out of that sensor, Nikon had to cram in a lot more pixels. The more pixels you cram onto a sensor, the less light gets in, the more noise it will produce at any ISO range.I really struggle to find someone who can give a clear answer to my question.
"Way" better camera? Not in my opinion. It's great if you need high resolution images and slightly better dynamic range at ISO 64, but in low light at high ISO the D750 will do a better job.
I see. Did you have the chance to shoot the same picture with same settings out of curiosity for comparison at that time? With same available light? The results were as you describe? How many stops is the D800 worst that D750 just have an idea?At one point of time we were using D800 and D750 for our wedding business. Regardless of the test results from DXO, in real life the D800 was noisier. Resizing to 24MP helps in minimizing the noise and makes the difference less obvious. I don't have personal experience with D800E, but I assume that their performances are similar.
its about 1/3 of a stop - 1/2 a stop at most in RAW at pixel level , resize the 800E image to 24Mp and the 800E wins ....... also the D750 has a pretty heavy AA filter softening the images - the D800E`s expensive cancelling filter effectively doesn`t have one .. that 36Mp sensor is still in the top group for a reason, its a hell of a performer even now full stop , the only advantage the 24Mp sensor has is smaller RAW files . Check DXO , the D600/610 have the same IQ as the D750 with less shutter shock for a fraction of the price , so long as you don`t need a fancy AF system , you`re laughing but I`d just get a D800E and have done - next worthy step is a D850I see. Did you have the chance to shoot the same picture with same settings out of curiosity for comparison at that time? With same available light? The results were as you describe? How many stops is the D800 worst that D750 just have an idea?At one point of time we were using D800 and D750 for our wedding business. Regardless of the test results from DXO, in real life the D800 was noisier. Resizing to 24MP helps in minimizing the noise and makes the difference less obvious. I don't have personal experience with D800E, but I assume that their performances are similar.
its basically a full frame D7200 - or a D600 with the AF it should have had to begin with and a flippy screen which is pretty useless because the live view is so badThe D750 is good, but it's basically a stripped down D800 with a standard resolution sensor. It lacks some of the performance features you have with the D800/E.
Thank you very much for this information. So we can say that the D800/D800E performance at ISO3200 is the same as the D750 but at ISO3200 lets say. Probably this is a good way to put, when we go out and compare both at 1:1 view each at their original pixel number.its about 1/3 of a stop - 1/2 a stop at most in RAW at pixel level , resize the 800E image to 24Mp and the 800E wins ....... also the D750 has a pretty heavy AA filter softening the images - the D800E`s expensive cancelling filter effectively doesn`t have one .. that 36Mp sensor is still in the top group for a reason, its a hell of a performer even now full stop , the only advantage the 24Mp sensor has is smaller RAW files . Check DXO , the D600/610 have the same IQ as the D750 with less shutter shock for a fraction of the price , so long as you don`t need a fancy AF system , you`re laughing but I`d just get a D800E and have done - next worthy step is a D850I see. Did you have the chance to shoot the same picture with same settings out of curiosity for comparison at that time? With same available light? The results were as you describe? How many stops is the D800 worst that D750 just have an idea?At one point of time we were using D800 and D750 for our wedding business. Regardless of the test results from DXO, in real life the D800 was noisier. Resizing to 24MP helps in minimizing the noise and makes the difference less obvious. I don't have personal experience with D800E, but I assume that their performances are similar.
just resizing the image to 6000 across in photoshop will do - I don`t use Lightroom , I use capture one for RAW and photoshop for everything else .....In regards to downsizing the D800/D800E file to the 24mpx, by that you mean crop the file at the same resolution as the D750 or is there a tool or procedure to do it in lightroom?
the D610 is the bargain of the newer cams , the only let down is if you need more than the centre focus point, the rest aren`t very sensitive , centre point wise its just fine ....... I`d watch used prices though, they can be up to as much as the D800I was actually looking at the D610 because I will be using the camera with manual lenses and not sure if this is a better investment instead of the D800E or D750. Is there anything one should know about the D610? Like problems, failures, recalls, etc?
Thanks for this piece of information. The thing is that I guess that if the quality of the light isn't great even the D750 will no perform considerably better or it can perform better but the file will not be that usable. That's my guess based on the use case of my 6D. I will also get the D750 in due time after testing the D800 to try it out and check this ISO performance.The D750 definitely has better noise performance at lSO 6400 or above, however I agree not much at the same resolution. (As in down sizing the D800E files to 24mp!) I would personally choose the D800E or D800/810. The prices are so low right now I would get a D810 used instead. Even if you have to save up for it, the D810 is a much newer and better camera. Not image quality wise, just about every feature or spec is better as is the lack of left focus issues. I tried to buy a D800 used years ago, I looked at three separate copies as the first two both suffered from the left focusing issue! So I recommend the D800E and or better yet the D819
There is nothing wrong with a D750 if all you care about is image quality and high ISO. My issue with the D750 is ergonomics, build quality and weather sealing. It’s a prosumer camera, while the D800/E/810 are all professional build quality and just feel better in your hands. I’ve played around with a friends D750 and it feels like a plastic fantastic camera to me. Of course that’s mostly because I own and use two D5 bodies and before that D4/D4s all the way back to the D1 in 1999. So I’m used to professional flagship bodies. I honestly wouldn’t worry to much about ISO 6400 nowadays and I agree the software is amazing, I use Topaz Denoise Ai and it’s amazing. I can shoot at 128O0 or 25600 without worrying!
I see. Just out of interest, when you say common output size I guess you mean bringing the 36mpx resolution to 25mpx? How do you do this? Just in case someone else doesn't answer. I have asked already above.The noise at high ISO levels is very similar between the two - not something where you can tell the difference with your naked eye if you use a common output size. The benefit of the D800E is going to be higher resolution, and when ISO is not a challenge, that resolution is pretty spectacular. If your lenses are up to the D800E, you can see a difference. I'll never forget my first set of photos with the D800E.
