bclaff
There are a couple of surprises with the Canon EOS R5.
The first is that it is the first Canon that I have tested that shows dual conversion gain, which starts at ISO 400.
The second is that there is Noise Reduction (NR) in the raw files at low ISO up to ISO 640.
Normally one only sees this at high ISO settings.
This is with all NR menu settings at OFF.
(I delayed publishing to confirm this with additional measurements.)
Here's the Photographic Dynamic Range (PDR) chart :
You can explore this and other measurements at the site.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
