lds2k
Well-known member
Can anyone recommend an on-camera flash for the CL besides the Leica flash units?
lds
lds
I ordered a Metz Mecablitz 26 AF - 2 that looks quite small and well balanced on CL. I had severs Metz flashes in the past and I have always been very satisfied. The Leica flashes are all made by Metz but several times more expensive with the red dot.Can anyone recommend an on-camera flash for the CL besides the Leica flash units?
lds
lds
Metz is making several version of the same flash for different camera brands. If you order one, make sure it is also for Leica.
IMO TTL is way overrated and is not worth the premium cost of Leica branded flashes. I've shot professionally for many years using Metz and other strobes with the auto thyristor/auto aperture technology. The results can be better than TTL. To adjust the flash output in 1/3 stop increments simply adjust the flash ISO.That is interesting. Metz do offer versions for most makes except Leica thus forcing us to buy the very expensive Leica branded version. Red Dots are not cheap!
Archie
Btw, if you go to the B&H website to check out the Metz flash, the hit shoe connections depicted are not the same as on my Olympus/Panasonic/Leica flash. Not sure what they are for, but it’s the same photo regardless of which camera manufacturer is chosen. Ironically those depicted on the website look like they would match the CL.
Archie, do you know of a good small third-party flash with the auto thyristor tech? Older/used OK. All the current models I've found are TTL/Manual. I figure that one of the smaller strobes would be nice for an M or Q. . . I use the pop-up flash on my DSLRs mainly for fill-flash and except for casting a shadow when using a Tokina 12-24 zoom at wider than 18mm they work really well.I agree. I often use my ancient Vivitar 2500 on my Leica M240 though I always use a Wein Safe-synch to be on the safe side despite Leica's claims that the M series cameras can tolerate quite high voltages. Better safe than sorry with such expensive equipment. The auto thyristor flashes do give good results.IMO TTL is way overrated and is not worth the premium cost of Leica branded flashes. I've shot professionally for many years using Metz and other strobes with the auto thyristor/auto aperture technology. The results can be better than TTL. To adjust the flash output in 1/3 stop increments simply adjust the flash ISO.That is interesting. Metz do offer versions for most makes except Leica thus forcing us to buy the very expensive Leica branded version. Red Dots are not cheap!
Archie
Used flashes with the auto aperture tech can be downright cheap. I don't know about the current models but older Metz flashes seem to work forever. I still use a Metz that I bought new in the mid 90s. It's my primary flash.
Archie
Louis,
It is possible that the contractual arrangements that existed between Metz and Leica may no longer apply as I think the most recent Leica branded flashes are made by Nissin.
lds
