Nikon 24-85mm VR or 24-120 VR
ZestandLeisure
New member
MA, US
I am planning to buy Nikon D810 and I am looking to buy a lens for travel/everyday use. I am not able to decide between these 2 lenses-
1. AF-S NIKKOR 24-85mm f/3.5-4.5G ED VR
2. AF-S NIKKOR 24-120mm f/4G ED VR
My primary question is between the two lenses, which is better at taking sharp images. Please let me know your experience
When I faced a similar decision a few years back (D800e), the 24-85 VR was not yet available. So I opted for the 24-120 f/4. The 24-120 is a fine lens. I have no real complaints with it. To demonstrate how much Nikon believes in this lens, they have embued it with the gold ring. The only drawback with the 24-120 is size and weight. It is a fairly substantial lens.
Had the 24-85 been available when I was looking I would have given it serious consideration as it is smaller, lighter, and less expensive. From what I have read about image quality on these two lenses, I doubt you would see much, if any, difference. The 24-120 will likely eke out slightly sharper corners when stopped down. I don't think you'll see any other difference in image quality.
These lenses have similar sharpness but the 24-120 has a better focal range, especially for travelling.
i had both lenses with my d600. The 24-120's sharpness wide open deteriorates above 80mm or so; of course the 24-85 doesn't even go there. OTOH @ f5.6 both lenses seem to perform quite well across the board in practical shooting; the long end of the 24-120 still is a bit softer though.
If money is tight and you don't tend to use the tele end and money's tight the 24-85 is perfectly useable. It is also a bit smaller/lighter.
But the 24-120 is a very practical general purpose/tourist lens. Take a couple of f1.8Gs primes for "perfect" shots and a tele-zoom and you all set.
A bulkier and heavier alternative -- but by all accounts consistent sharpness everywhere -- is the Sigma 24-105. i did not pick it due to the size, bulk, tele end, and a past history with Sigma quality (not that Nikon is perfect). But it is probably the best FF mid-zoom optically at this point.
-- gary ray
Semi-professional in early 1970s; just a putzer since then. interests: historical sites, virginia, motorcycle racing. A nikon user more by habit than choice; still, nikon seems to work well for me.
what is the price difference?
I was extremely disappointed with the 24-120 b/c images above 80mm are completely soft wide-open. So you have to either keep the lens at F/5.6 to get acceptable results above 80mm or remember to close it down at F/5.6 . If you forget to close it down, you'll end up with a bunch of soft images but if you keep it closed at F/5.6 then why the premium for a constant F/4 lens?
Either way, if they are priced the same or with-in $50 of each other, get the 24-120, otherwise get the 24-85mm and just walk a few steps or crop to make up for the 120mm.
I own both lenses, and regularly use them on a D810 (and on other bodies). The 24-120mm is my main portrait and general purpose lens and the lighter, smaller 24-85mm gets used for travel etc.
If sharpness is your main concern, I don't see much difference between them in the overlapping focal length range. The 24-120mm isn't quite as sharp at the longer end wide open, but it's still quite acceptable (to me) - and of course the 24-85mm doesn't give you that range at all. I posted a couple of examples at 120mm and f/4 over in this thread.
The 24-85mm does seem to suffer from a little more distortion, but for both lenses this is easily corrected in PS or Lightroom so I don't worry about it.
Focus speed also seems about the same - neither is blazing fast like a 300mm f/2.8, but they are still very good.
-85 is still considered a hidden gem, and mine survived a full dip in a pool, so at the very least it is pretty water-proof besides being rated somewhat resistant. Otherwise I do bulk of my work with it to a point where front rubber ring is floppy and loose, but the lens just keeps on going and going.
Had 24-85VR w/ D800. All my gears were stolen on vacation last July.
Bought Sigma 24-105Art w/ D750.
Don't have any experience with 24-120mm VR
Comparing Nikon 24-85VR and Sigma 24-105Art, the biggest IQ difference is the contrast wide open. IQ w/ Sigma is snappier at all focal length. 24-105A also looks sharper even w/ 24mp on D750 than 24-85VR w/ 36mp on D800. 24-85VR is quite a bit lighter though.
When I bought this one, I had just about the same usage in mind. When talking about sharpness, I have no complaint. If field curvature and distortion is a problem or not, is all about the subject's character.
But the ergonomics doesn't fit me at all, and this is the only lens I have, that I don't master to use with mittens. So my intentions in using it as a winter lens, was not workable.
If sharpness is all you care about, I have no problem recommending the 24-85mm. I have no experience with the 24-120mm, so I can't say if that one is better or worse.
I used to own the 24-85MM VR and kept the 24-120 F4 for extended range, nano coat. I have a very sharp copy.
Will most likely keep until if/when Nikon updates it to E FL version.
When I bought a D810, I initially used primes (1.8G - 20, 28, 50, 85), as well as a 70-200/4. When a 24-85 was available as a refurb (almost silly cheap), I picked it up and it's become part of my regular travel kit. Since I already had the 70-200/4, the longer range of the 24-120 didn't matter. My travel kit is now - 20/1.8G, 24-85VR, 70-200/4 and a Voightlander 58/1.4. If a new 24-120 matched the 70-200 in the overlapping range, I'd think about it.
In general D810 is $2500, 24-85mm VR is $500 and 24-120 VR is $1100; but if I buy camera & 24-120 VR combo, the special price they are offering now is $3200. But what I read from all the forums & blogs that 24-85mm VR takes sharp images. But after reading all your comments here I am planning to buy the combo offer (D810 & 24-120 VR).
I own the 24-85 and like it quite a bit. When I was looking for a zoom I also considered the 24-120, and I read a lot of reviews that said the two lenses deliver pretty indistinguishable IQ. So in the end I went with the smaller and lighter package.
For me, I really do value smaller and lighter when possible. It's not that I can't carry heavier lenses, but I feel like big lenses can make you a whole lot more conspicuous in many situations, and that's just not something I'm interested in. This is why, for example, I own the Nikon 35mm instead of the Sigma 35mm, even though I had the Sigma 30mm on DX and loved it.
I too faced this dilemma recently so will give you my findings and opinion which is heavily based on my budget and needs (not necessarily yours) and a few test shoots, rather than a lot of user experience:
I tried a few samples of the 24-120 f/4 and the experience left me rather underwhelmed. That's not to say it was worse than the 24-85 VR. It just wasn't really any better. Certainly not over twice the price better.
I would far rather the 24-85vr plus the money for extra travel budget.
Or, as a travel photographer I find a fast prime indispensable. You could team the 24-85 up with a 50mm 1.4 for about the same money and weight.
Plus, with the D810 you have plenty pixels to spare to digitally zoom upto 120mm
Rgds, NN
My Travel Photos
I had both lenses, let the 24-85 go when I sold my D610.
I think the 24-120 has just slightly nicer contrast. Both were equally as sharp as far as I can tell.
Photography gear (in general) follows the principle of diminishing returns.
The 24-120 is a better lens all around. But it comes in a bigger, heavier, more expensive package. Only you can decide if the IQ improvements are "worth it".
I use the 24-120 and have been quite happy with it (although I tend to shoot my 35 & 85 primes more).
FYI here are some info/examples from another thread also asking about the 24-120 f/4 VR.
Nikkor 24-120 f4...
...The lens is surpisingly sharp and extremely versatile. outdoor pets, kids, etc would not be a problem at all with the d750. I have used it for kids a lot. I find it does very well with landscapes also....
Ben Kanarek recently used this lens for the cover shot of Elle magazine (search for his post on dpreveiw).
I have tested the 24-120 F4 against the Zeiss 21 2.8, Zeiss 2/25, Sigma art 20mm, Nikon 28mm 2.8 AI-S, Nikon 28mm 1.8g, Nikon 24-70 2.8 (non VR), and I couldn't find a big enough difference in IQ to justify purchasing any of those for landscape use. It's a real bargain when purchased in the d750 kit.
Some shots for examples:
Police Officer (Retired)
The out of focus areas are slightly better with the 24-120, the greens are a little softer (which I like) and the sharpness sweet-spot is around 50ish mm where it is tack sharp, however going past 80mm the lens falls off the cliff, has to be closed down to at least 5.6, preferably F/8 for decent results,
I have both lenses and use them on a D750. The image quality is very close between the two and will require pixel-peeking to notice. The main advantage of the 24-120 is the constant f/4 maximum apertures and the 85-120mm range. The disadvantage of the 24-120 is its size, weight, and cost.
I do think the 24-120/4 renders richer colors.
I mostly use the 24-120 along with the 20 1.8 for much of my hiking ventures. I'm surprised how well the tele has held up to my 24-70 2.8. I also have the both the 2.8 and 4 70-200 and for more reach of your tele along with the 24-85 is a good idea but I prefer less weight and lens changing. I researched quite a bit between these two lenses the OP is pondering and the bulk stated the 24-120 was better overall in the overlapping range. I wish they would make a 24-70 4 though. Canon does. If they did then I'm sure I'd switch over to using my 70-200 more and deal with an added lens.
