Last month I visited Kgalagadi Transfrontier Park in South Africa/Botswana and used my new Canon EF 100-400mm mk II zoom lens extensively with a gimball head mounted on an Apex beanbag (this one: http://www.bhphotovideo.com/c/produ...159002316_Bean_Bag_Realtree.html/prm/alsVwDtl)
To my surprise, after a couple of days the lense wasn't stable any more: it became a bit wobbly when I used it with the gimball head.
It took me some time to figure out what the problem was, but in the end it turned out that the four little black screws that tighten the tripod mount to the lens were loose (see picture).
In a period of two weeks, I had to tighten these screws at least four times.
The road conditions in the Kgalagadi park are not great (sand and gravel with lots of corrugation) so there's a lot of rattle, shake and tremble when you drive there, but I did not expect that a Canon lens costing more than € 2000 would fall apart under these circumstances ;-)
Just to be sure: of course I did not drive around with the lens mounted to the gimbal head on the beanbag. Every time we drove a long distance, the lens was carefully stowed away in my LowePro bag.
I would like to know if anyone else is having the same issue with this lens?
