www.rawdigger.com
So the compression is an issue for the 0.01% of people that want to shoot star trails and not have artifacts at 1:1 view. I think for most, this is a non issue. It's also quite possible they have done something in the A7 ii to fix this but they probably won't come out and say it as it would be an admission that there was an issue in the past.Did they fix the lossy compression that does cause real image quality artifacts in some situations (such as photographing star trails).
I agree it doesn't cause image quality artifacts in most situations. But that's neither here nor there. The fact is - lots of people complain that the Nikon D810 has "better" image quality than the A7R and this is the reason for the complaint.
This is about PR and marketing - I'd probably go ahead and use compressed RAW in most situations. I just want to know if Sony has taken care of the PR black eye here, or not.
Note that exposure is pushed two full stops at the post processing stage here! And this is for an ultra-exreme-high-contrast scene, where the star trails are heavily overexposed and the sky background is underexposed. What about other raw peocessors and more normal exposure/post processing?In most cases the compression certainly is no issue. But:
http://www.rawdigger.com/howtouse/sony-craw-arw2-posterization-detection
This is files that are pushed way beyond the dynamic range of the sensor. Read my post above.So the compression is an issue for the 0.01% of people that want to shoot star trails and not have artifacts at 1:1 view.
And CaNikon struggle with slamming mirrors (old tech) and shutter shake (no electronic first curtain except for Live View for some Canon models, old tech) ... they messed everything up too ... lol!Sony messed it with a wrong decision (lossy raw) and a construction mistake (shutter vibration).
Well, yes. Nevertheless Sony limited the capabilities of its sensor. Give me the option to have it lossless and I'm fine. Might be possible with an firmware update.Note that exposure is pushed two full stops at the post processing stage here! And this is for an ultra-exreme-high-contrast scene, where the star trails are heavily overexposed and the sky background is underexposed. What about other raw peocessors and more normal exposure/post processing?
Sure, by pushing files or dynamic range to extremes, you can construct a lot of "problems" never affecting ordinary photographs.
When I had Sony aps-c and full frame cameras with lossless and lossy raw file formats, I wasn't able to find any differences between the files, even when pushing demanding astrophoto files.And btw., your argumentation reminds me a lot of what Canon fanboys said about the difference between Canon and Sony sensors ...
There are other image quality issues that are much more important than the star trail flaws/ultra-extreme contrast edges, but since these aren't "forum talk" nobody are asking for a fix. A bit strange, or what?There aren't any star trails there.
In any event, this is about perception not reality. The perception is, Sony cameras are not capable of the ultimate an image quality because of the RAW compression. Just give an option for uncompressed raw and we won't have to hear about this anymore.
Post an example.I read the announcements carefully, and I didn't see anything in there about better-than-11-bit ARW tonal depth or a non-lossy block compression algorithm being available as options, unfortunately.
Let's see what the final product has, though. It's conceivable that Sony would make an improved ARW format available deep in the menus of a new camera and not want to publicize it too much.
I do wish that people would stop insisting that 11-bit lossy block-compressed ARWs aren't a problem for me.
I do want it.I just don't get this argument that so many people make against a desire for a true 14-bit non-lossy ARW format option.
Would they be okay with Sony reducing the tonal range of ARW to 10 bits? 9 bits? How about a lossy block compression algorithm that saved more space by posterizing the intermediate pixels to 6 bits, or 5 bits, from 7 today.
At some point, it starts to matter, right?
