James K Cheung
Leading Member
Hi, Is there a way to download images from cf card to an external hd using my Nexus7 ?
Jim
Jim
What about plugging in a powered hub to the OTG cable and powering the HDD from that?Ken Gosden wrote:
Jeff, I agree that a few USB drives might be the way to go on the Nexus. Using the WiFi HD was the only option when I started this adventure. But now that Nexus Media Importer can both read and write I am considering the 32 or 64 GB thumb drive option. Certainly smaller and lighter, just not cheaper or as much capacity. My last trip filled around 120 GB in two weeks, so HD's are still useful.
So what I gather from this, Ken, is even if you have a self-powered HDD, Nexus Media Importer may not work, and if we want a guaranteed HDD backup workflow it'll have to involve a photo vault like a UDMA 2. Ouch.Ken Gosden wrote:
I doubt it. The Node is self-powered so it did not have any issues in that regard. I think there are still some limitations in the Nexus Media Importer app. I will continue to test other drive and hub combinations. But I am getting more comfortable with the idea of spending the money for a few big flash drives. They are still cheaper and smaller than an SSD.
That is pretty much perfect, Ken. Pretty much obviates the need for a photo vault unless you want to review the RAWs directly or need to recover "lost" images from a dying hard drive. Not as flexible as a full multiple-peripheral host mode, but a great cost-saving feature as you don't have to pay Samsung's prices for their lesser-spec'd display and larger physical size. Now let's hope whatever the Nexus 7 II is this July won't prang Media Importer's functionality.Ken Gosden wrote:
Just gave the direct copy from USB drive to USB drive via the powered hub a try. IT WORKS. Under advanced mode in Media Importer I was able to select both a USB thumb drive and USB HD that were connected to the same powered hub as source and destination. The names are a bit cryptic, something like xyz.xyz.usb4 and xyz.xyz.usb3 (did not write the exact names down), but just make certain to select one as source and one as destination. It does appear that in this case the transfers are only one direction based on this selection process. This is unlike using the internal Nexus memory and one external USB device. In that case you can transfer both ways easily. Regardless, Nexus Media Importer has effectively rendered the need to use my internal memory at all. This makes the Nexus tablets nearly as useful as any with integrated USB host modes.
