rwbaron
I was hoping others could add some experience to a quirk I came across yesterday performing AF micro-adjust on all my lenses. Everything was going well until the 70~200f4LIS. This lens is tack sharp on my 50D (no MA needed), 40D, XTi and 10D. I encountered a strange issue after testing under the following conditions:
Tripod mounted
Mirror lock
2 second timer
200mm at f4
33 feet from target (50x FL)
Flat black & white target with various levels of detail (well lit)
Center point AF
Single shot
Taking 10 shots and manually defocusing the lens to infinity between each I only get about 50% that are tack sharp with the rest noticeably OOF. What's really strange is when I attach the Canon 1.4x and test at 280mm f5.6 the lens accuracy is fine with all shots in focus. My 100~400 also exhibits this same problem on the 7D. Both lenses are fine on my 50D and the 7D has no apparent problem with my 8 other lenses one of which is the notorious 50mm f1.4.
Anyone else seeing anything similar to this? I spoke with Canon tech support this AM and they felt there is nothing wrong with my method and suggested sending the 7D and both lenses to Canon service. I really don't want to do this especially if it's just a 7D quirk or something with early production firmware. I'm confident it's not a lens issue because the 70~200 is perfect on my other bodies and the 100~400 works properly on the 50D with considerable micro adjustment (-10). I plan on doing more testing tonight but it would shed some light on where the problem might be if other 7D owners were seeing similar results.
Thanks,
Bob
http://www.pbase.com/rwbaron
Tripod mounted
Mirror lock
2 second timer
200mm at f4
Center point AF
Single shot
Thanks,
Bob
