C 5060 mode dial replacement
peter ford
Forum Enthusiast
UK
I replaced my first c5060 mode dial this morning.i have done a few c 5050 mode dial's but never had the chance with a c 5060.The c 5060 mode dial is abit more awkward than the C 5050,but screws onto the back cover like the C 5050.So anybody that has a Camera sitting around with a dodgy mode dial,it is worth worth fixing if you are handy with a screw driver.
Cheers Pete
http://mrpeterford1860.fotopic.net/
A screwdriver? Is that all it takes? I have been waiting for a post like this.
Are the 5060's problems just mechanical, or can there be something deeper? Did you have to buy new parts? I have wondered if it's just a matter of cleaning a set of contacts but I thought the problem required deep electronic surgery. I would love to get mine fixed.
Recently I replaced both the Mode dial and the Zoom/Shutter assembly on one of my "Pawn Shop" c-3020z cameras. They, (the little wiper fingers) were very corroded. Maybe some "TV" contact cleaner would have worked?
The next time you have one of the c5050 or c5060 apart, how about some pictures? I have some pictures of the UZI and the c-3020z disassembled and can find some of the c-2020-c2040 that are on this forum. Also I think there is a set of pictures for the c-750 as well.
Be nice if we could gather them all up in one place and have Bill Huber do a separate gallery?
My small screwdrivers (Phillips) came in a set from Radio Shack. About $5 US.
Other than the screws being very small they want to play hide-an-seek so handle with care.
Paul
like this.
This mode dial causes loads of different problems,you can take the bottom of the mode dial off,but you cant get to the top half to clean the contacts.
You will have to buy a mode dial switch,i bought mine from a Olympus camera repair shop.You have to take the screws out in some kind of order,because they are different sizes.The mode dial is screwed to the back cover of the camera.
There is a site that tells you how to take the c5050 apart to replace the mode dial,its almost the same.its well worth doing,i can find a link if required.
You cant really get into the top part of the c5050 and c5060 mode dial,its screwed into the back cover of the camera.its not like the switch on the c3020 etc.i have tryed to spray cleaner in the switch on the c5050,it can work sometimes,but it does come back again.the new mode switches are made different inside,so theres no problem with them.
well.
There is a site that shows you how to replace the c5050 mode dial with pictures.i can find a link if required.
I'd be happy to get this link.
Thanks!
Prog.
the above link has the repair job.
I suspected my problem was the control dial rather than the mode dial. It now seems that this was really just a matter of semantics as the power switch, control dial, and mode dial are all one assembly anyway. Olympus part # VC799700, called Unit,CMD. I should have looked at the parts manual before and seen the bleeding obvious. Controls like that are bound to come as package. and I guess this explains your previous comment about this being responsible for a raft of problems.
Do I read that right?
I use the part diagrams for part numbers,so you know what to order.
The mode dial cost £19.00 + postage here in the UK.if you look at the c5050 link,you can see what the mode dial looks like,they look the same on both c5060 and c5050 cameras.
Yes they are all one unit,you have two dials and the on/off switch,all together.for some reason on the c5060,it causes loads of problems when it goes wrong,it can make the camera unusable,the camera i had to fix,the lens would not always come out.but on the c5050,its just the on/off switch that plays up.that is the part number i ordered VC799700 ,if its got a blob of white on the ribbon on the new switch,this means it is a updated switch unit,which should work forever.
if you buy a mode dial/switch,let me know if you get stuck.
The "Golden Age" of Olympus may yet return!
A most interesting report. And, for the first time, I understand what is going on....
Further on this saga.
The parts manual I posted above identifies the screws size and length.
It would pay to have a vernier so that you can check their length if needs be and they can be kept more safely in one container.
at the abovementioned site http://www.molon.de/5050/modedial/
The hotshoe spring comes out quite easily. Both the front and back edges have a turned-down edge. The front can easily be lifted by putting a blunt needle under the spring at the point where the is a relief for the locking pin. The spring may then be slid back, helped by a knife blade. The back edge then bears aganst a mould on the body but by then the front edge is no longer a problem. The same tool can be used to lift the back edge over the obstruction, et voila, out comes the spring.
Remove the camera strap.
In the picture series:
Screws 1 and two are not the same. Screw 1 is shorter and fatter.
There are four screws under the doors and plug covers, two at each end, all the same, with course threads.
Note that trhe red pointer for the mode dial is in the front section of the body. It appears that this is a good place to ease the back off.
There isn't much holding the card cover in place. It just fell on the floor and the pin falls out too.
The screw under the strap lug is not a player. The actual lug above it comes off with the back.
The panel with the USB socket etc stays on the front section.
The battery door is not connected to the back cover.
While I stick with Molon's comment about the front screws of the hotshoe staying inplace, it seems that loosening them a little helps the process a lot.
Once the back is been eased of about 3mm it comes away quite easily.
The first item to give you a hard time ans sweaty palms, is a ribbon cable that connects to the front section by the battery door hinge. Take a deep breath, slide the screwdiver shaft under it, grip the ribbon with your thumb, and ease it out. The ribbon is in full view in picture 10 but the circuit board and buttons are different. I could not swing the back over like in the picture, without unplugging the ribbon.
The other cables are different oo but they can remain in place.
The delete button is not a player but the circuit board is fouled by the mount for the screen. It is released by undoing three screws in a row under the screen and one inside right at the top. No need to go any further, You now have access to the vital screw.
I'm not going any further at the moment. I know I can get the dial out if I get a new one. Now that I have good access all round the dial I'm going to give it a good squirt with Electrolube and see if it helps.
the back off.
it helps.
Very good,yes the only thing you got to be carefull with,is those ribbons,the bottom one is the worst,its hard to get back in,but does if you take your time.yes i loosen the other two flash shoe scews,the back is tight otherwise.You can undo the bottom of the mode dial,but not the top part.so you can clean the bottom dial.
Does the Electrolube evaporate after it cleans.
