Zone Ruler
123val
Active member
London, UK
Hi,
I've been learning about the zone ruler and how to assess a scene and meter accordingly. However, I've also purchased a gray card and want to check if my understanding is correct as to why I would use this. If I expose according to the light falling on the gray card, when I remove the card from the scene (and my meter readings go crazy) I would ignore this and make no further changes to the setting
i.e. use one or the other, zone ruler or gray card, rather than both
Laura
Hi,
You mean the Ansel Adams Zone System? That?
The gray card is a tool and can be used as part of the Zone System technique
The Zone System is a tonal zones visualisation system. You use it to understand how to place a particular tone that is of the scene with respect to the gray card.
The gray card is just a tool to reflect back to you what 18% gray is - it is a reference point.
You start off using the Zone System technique in M - full manual f/no, shutter speed and ISO. When you use M, the meter readings don't change camera settings. You read from the meter and you change the settings yourself
Ananda
http://www.dpreview.com/articles/6861540877/a-compilation-of-tips-for-beginners
http://anandasim.blogspot.com/
http://gplus.to/anandasim
'Enjoy Diversity - Live a Little or a Lot'
What most people don’t understand about Ansel Adam’s zone system is that it included both exposure and development. He’d expose the negative in order to support the development process. In this way he could place the tones of the image exactly where he envisioned. What’s important to realize is that the Zone System was used to create images that matched Adam’s vision of the scene...not necessarily the way things actually looked.
In the digital era, the Zone System has been largely replaced with different techniques. One specialized technique is called expose-to-the-right, where the driving force is to protect highlights or to maximize exposure. The tool of ETTR is the histogram. ETTR is combined with post-processing to create the final image. A more common technique is to simply expose the subject correctly. That’s where a gray card comes in.
If you take a picture of a black wall, it comes out gray. If you take a picture of a white wall, it comes out gray. The black wall was overexposed and the white wall was underexposed. The reason is that the camera is trying to make everything gray. Since the camera is trying to make everything gray, the best way to achieve “standard” exposure is to let the camera meter something that actually is gray. So you put a gray card in front of the camera, angled to catch the light that’s lighting the scene, and you spot meter the card. Now you have standard exposure.
Whether standard exposure is the exposure you want...that’s another question entirely. You may want to purposely over or under expose the image for esthetic reasons. That’s a decision that only you can make.
The easiest way to use a gray card is with Auto Exposure Lock. You point the camera at the gray card and you press the AE Lock button (I find it easier to configure the camera’s AE Lock to hold the lock after the button is released...some cameras hold the lock by default, so this isn't necessary.) Once the exposure is locked you can now adjust the setting under your control. For example, if you’re in Aperture Priority, you can change the aperture and the camera will change the shutter speed to maintain the locked exposure. That makes it very easy to control the effect of the aperture (or shutter in Shutter Priority) without having to worry about keeping the correct exposure with every change...as you do with Manual mode. If you don’t have a gray card handy, you can use nature’s “gray” cards...blue sky about 45 degrees up or the sunny side of green grass. Just point and press AE Lock.
A gray card is of no use when the light is constantly changing. When light is changing, consistent exposure on a subject is achieved by using auto modes and metering the subject directly, while applying Exposure Compensation. Let’s say your subject is a bride in a white dress. Well, we already know that white objects get underexposed. You can set the camera to Center Weighted or Partial metering (depending on your brand of camera) and apply EC of +1.3 or so to achieve standard exposure. Now, no matter how the light changes, your exposure of the bride will always be the same. With experience you’ll learn how much compensation is needed for various subjects. Light skinned faces usually need +1 EC. Black cats and dogs may need -1.3 EC. It’s a question of how much darker or lighter the tone is from 18% gray.
Here's a chart that gives the EC necessary to capture the color as you see it, when spot metering the color in question. Light colors need positive EC and dark colors need negative EC.
Thank you for the incredibly easy to understand explanation Graystar!
I'm here to learn :)
An item most people don't know is that AA's zone system changed as he aged. There was an AA retrospective a few years ago that showed the change in prints from some of his early negatives.
If you ever read his books you will note that he thought all images should tones from absolute black to not detail white. If you check out the B&W forum you will see images that ignore that rule to their peril.
Mike
Gray cards are designed to reflect 18% of the light as stated above and they are a good starting point for most exposures but are rarely "perfect" exposure. You can also use something like a tribalance card which has grey, white and black. You take the shot with the triblance in the picture and can later determine the white piont of the image as well as the dynamic range (to an extent). Alot of people also recommend the 12% grey card which is made by Lastolite. Don't get a cheap grey card, the grey fades over time.
Another important skill to develop is the ability to determine a 50% grey in a coloured scene, like a landscape for instance. You can practice by getting a reading off the grey card and then pointing the camera at something that gives you the same or similar reading, like concrete, darker grass patches, some types of bark etc. This will train your eye for exposure outdoors for when you don't have a grey card with you. I also take a couple of shots before hand and then check them in the LCD. Zoom in, have a good look. This way, no matter where you are, even with no grey card you should reach the best exposure values in less than half a minute.
This isn't the end of story however. How often do you see landscape shots where the sky is exposed well but the details in the shadows are lost or the details are there but the sky blown out? This is why a good landscape photographer will always shoot multiple exposures often in raw and then PP for an excellent outcome. Good luck.
