It's been probably a week since I actively used SnapBridge with my Z8. I just checked, and the camera is less than a second off my iPad time, which is regularly synced with NIST.Can the Z8 timecode jam? And is the timecode steady enough to run by itself for a day?
Being able to run the camera without attaching or setting up additional timecode units would be very welcome![]()
As you are no doubt aware the purpose of saving timecodes with recordings is to enable recordings to be sync'd across multiple devices in post production. AND such timesync data has to be accurate and precisely the same in every recording device for this to be successful.Can the Z8 timecode jam? And is the timecode steady enough to run by itself for a day?
In a different topic I explained how you can actually use just the cameras to synchronize their times via the "Connect to another camera" feature. Put one in control mode, and the others in remote mode. Sync the time. You now have a common timesource.As you are no doubt aware the purpose of saving timecodes with recordings is to enable recordings to be sync'd across multiple devices in post production. AND such timesync data has to be accurate and precisely the same in every recording device for this to be successful.Can the Z8 timecode jam? And is the timecode steady enough to run by itself for a day?
So yes you can instruct the Z8 and Z9 to utilise current time and you can use snapbridge to set the time AND when recording the timesync records time in 1/100th second intervals.
Without a live common timesync source (like an ultra sync one or blue - both of which are tiny) you may have to correct the recorded timesync values if there are any difference --- that is fine for one or two clips but not for hundreds or thousands.
And what about field recorders and other recording devices on your set?
Far FAr easy to just pick up an UltraSync Blue - pair all recorders to it and use it as the timecode source -- then you have no issues down the line.
What I'd really like to do is jam-sync my Sound Devices recorder to the camera, or vice versa. But it seems that this is not an option, as the Z8 does not have timecode output, or input. And the field recorder can not fetch time code via bluetooth...As you are no doubt aware the purpose of saving timecodes with recordings is to enable recordings to be sync'd across multiple devices in post production. AND such timesync data has to be accurate and precisely the same in every recording device for this to be successful.Can the Z8 timecode jam? And is the timecode steady enough to run by itself for a day?
Not true - the Z8 and Z9 both have the ability to output timecode via HDMI.What I'd really like to do is jam-sync my Sound Devices recorder to the camera, or vice versa. But it seems that this is not an option, as the Z8 does not have timecode output, or input. And the field recorder can not fetch time code via bluetooth...As you are no doubt aware the purpose of saving timecodes with recordings is to enable recordings to be sync'd across multiple devices in post production. AND such timesync data has to be accurate and precisely the same in every recording device for this to be successful.Can the Z8 timecode jam? And is the timecode steady enough to run by itself for a day?
I meant LTC. Can't jam-sync the Sound Devices to HDMI timecode, unfortunately.Not true - the Z8 and Z9 both have the ability to output timecode via HDMI.What I'd really like to do is jam-sync my Sound Devices recorder to the camera, or vice versa. But it seems that this is not an option, as the Z8 does not have timecode output, or input. And the field recorder can not fetch time code via bluetooth...As you are no doubt aware the purpose of saving timecodes with recordings is to enable recordings to be sync'd across multiple devices in post production. AND such timesync data has to be accurate and precisely the same in every recording device for this to be successful.Can the Z8 timecode jam? And is the timecode steady enough to run by itself for a day?
Ah. Gotcha.I meant LTC. Can't jam-sync the Sound Devices to HDMI timecode, unfortunately.Not true - the Z8 and Z9 both have the ability to output timecode via HDMI.What I'd really like to do is jam-sync my Sound Devices recorder to the camera, or vice versa. But it seems that this is not an option, as the Z8 does not have timecode output, or input. And the field recorder can not fetch time code via bluetooth...As you are no doubt aware the purpose of saving timecodes with recordings is to enable recordings to be sync'd across multiple devices in post production. AND such timesync data has to be accurate and precisely the same in every recording device for this to be successful.Can the Z8 timecode jam? And is the timecode steady enough to run by itself for a day?
This is a little out there, but ...I meant LTC. Can't jam-sync the Sound Devices to HDMI timecode, unfortunately.Not true - the Z8 and Z9 both have the ability to output timecode via HDMI.What I'd really like to do is jam-sync my Sound Devices recorder to the camera, or vice versa. But it seems that this is not an option, as the Z8 does not have timecode output, or input. And the field recorder can not fetch time code via bluetooth...As you are no doubt aware the purpose of saving timecodes with recordings is to enable recordings to be sync'd across multiple devices in post production. AND such timesync data has to be accurate and precisely the same in every recording device for this to be successful.Can the Z8 timecode jam? And is the timecode steady enough to run by itself for a day?
By far the quickest easiest and cheapest solution is to buy an UltraSync One or Blue assuming you audio recorder can pair/work with it.What I'd really like to do is jam-sync my Sound Devices recorder to the camera, or vice versa. But it seems that this is not an option, as the Z8 does not have timecode output, or input. And the field recorder can not fetch time code via bluetooth...
I think the issue is that his Sound Devices recorder can not fetch time code via bluetooth, so that means he’d need an UltraSync One. And the Z8 can not have timecode input via wired connection - it can only get it from it’s timeclock, manual input or Blue. So he’d need both, and he’d need to configure the One and Blue in a master/slave relationship so that he can sync the timecodes.By far the quickest easiest and cheapest solution is to buy an UltraSync One or Blue assuming you audio recorder can pair/work with it.What I'd really like to do is jam-sync my Sound Devices recorder to the camera, or vice versa. But it seems that this is not an option, as the Z8 does not have timecode output, or input. And the field recorder can not fetch time code via bluetooth...
One source that all recorders sync with (accept Timecode jamming from).
[you will get there in the end].
Yeah, it seems like an UltraSync One/Blue combination is required. Or maybe they'll release a BlueOne so I can get by with only oneI think the issue is that his Sound Devices recorder can not fetch time code via bluetooth, so that means he’d need an UltraSync One. And the Z8 can not have timecode input via wired connection - it can only get it from it’s timeclock, manual input or Blue. So he’d need both, and he’d need to configure the One and Blue in a master/slave relationship so that he can sync the timecodes.By far the quickest easiest and cheapest solution is to buy an UltraSync One or Blue assuming you audio recorder can pair/work with it.What I'd really like to do is jam-sync my Sound Devices recorder to the camera, or vice versa. But it seems that this is not an option, as the Z8 does not have timecode output, or input. And the field recorder can not fetch time code via bluetooth...
Economically it would be wonderful if the Z9 or Z8 could take timecode LTC via the mic jack input, because then he could do an LTC jam into his Sound Devices recorder and to the Z8 or Z9 with a single source.
But on the plus side, it should be doable with one of each.
I still think you should try the “hack” I suggested with an HDMI splitter for $16 and see if you can make it work. Just think of the fun satisfaction I’ll have when you report that it works. And you really want that, right? Right?Yeah, it seems like an UltraSync One/Blue combination is required. Or maybe they'll release a BlueOne so I can get by with only oneI think the issue is that his Sound Devices recorder can not fetch time code via bluetooth, so that means he’d need an UltraSync One. And the Z8 can not have timecode input via wired connection - it can only get it from it’s timeclock, manual input or Blue. So he’d need both, and he’d need to configure the One and Blue in a master/slave relationship so that he can sync the timecodes.By far the quickest easiest and cheapest solution is to buy an UltraSync One or Blue assuming you audio recorder can pair/work with it.What I'd really like to do is jam-sync my Sound Devices recorder to the camera, or vice versa. But it seems that this is not an option, as the Z8 does not have timecode output, or input. And the field recorder can not fetch time code via bluetooth...
But on the plus side, it should be doable with one of each.![]()
You only use ONE UltraSync to jam timecode to all your devices - the Blue uses Bluetooth. The one has more options and there are a host of physically attached alternatives.Yeah, it seems like an UltraSync One/Blue combination is required. Or maybe they'll release a BlueOne so I can get by with only one![]()
The One doesn’t do Bluetooth, and the Z8 and Z9 do not allow for timecode input other than manually entered, internal timeclock or bluetooth.You only use ONE UltraSync to jam timecode to all your devices - the Blue uses Bluetooth. The one has more options and there are a host of physically attached alternatives.Yeah, it seems like an UltraSync One/Blue combination is required. Or maybe they'll release a BlueOne so I can get by with only one![]()
Ah, I see what you mean when looking at the linksI still think you should try the “hack” I suggested with an HDMI splitter for $16 and see if you can make it work. Just think of the fun satisfaction I’ll have when you report that it works. And you really want that, right? Right?Yeah, it seems like an UltraSync One/Blue combination is required. Or maybe they'll release a BlueOne so I can get by with only oneI think the issue is that his Sound Devices recorder can not fetch time code via bluetooth, so that means he’d need an UltraSync One. And the Z8 can not have timecode input via wired connection - it can only get it from it’s timeclock, manual input or Blue. So he’d need both, and he’d need to configure the One and Blue in a master/slave relationship so that he can sync the timecodes.By far the quickest easiest and cheapest solution is to buy an UltraSync One or Blue assuming you audio recorder can pair/work with it.What I'd really like to do is jam-sync my Sound Devices recorder to the camera, or vice versa. But it seems that this is not an option, as the Z8 does not have timecode output, or input. And the field recorder can not fetch time code via bluetooth...
UltraSync blue/one are both supported by Nikon for the Z8 and Z9Is the Ultrasynch a better alternative to the Deity TC-1? I feel like implementing Timecode in camera without the ability to jam synch is almost pointless. I'm hoping you guys with more knowledge and experience will add more to this thread.
But the UltraSync Blue is the only one talking to Z9/8, no? Or does the One also transmit over bluetooth?UltraSync blue/one are both supported by Nikon for the Z8 and Z9Is the Ultrasynch a better alternative to the Deity TC-1? I feel like implementing Timecode in camera without the ability to jam synch is almost pointless. I'm hoping you guys with more knowledge and experience will add more to this thread.
AND I know they work - I have them and use them.
I have never heard of the product you mentioned.
Yes - I only use the Blue and prefer not using cable connection for TC.But the UltraSync Blue is the only one talking to Z9/8, no? Or does the One also transmit over bluetooth?UltraSync blue/one are both supported by Nikon for the Z8 and Z9Is the Ultrasynch a better alternative to the Deity TC-1? I feel like implementing Timecode in camera without the ability to jam synch is almost pointless. I'm hoping you guys with more knowledge and experience will add more to this thread.
