Hello folks,
I have an idea to use a Z30 along with a lens or telescope plus external HDMI 4K monitor to use as a spotting scope / digiscope. (But not literally digiscoping with an eyepiece and lens) There is NO recording device attached to the HDMI. Regarding the HDMI output at 4K,
1) Does it use the full area of the sensor? (And then downsizes or bins the pixels in such a way that it still works well with low light? i.e. it will average the pixel values instead of just skipping pixels)
2) What zoom levels would be available - while not throwing away in-between pixels?
3) I assume it can get clean output in just "live view" mode, and doesn't require recording?
4) What difference does it make if the camera is in video or photo mode?
5) I heard that there's an overheating problem. Any other gotchas?
The main use case for now is just as an archery target spotting scope. I have a camera + telephoto lens + 4K portable monitor + battery all mounted on a tripod. Currently using a micro 4/3 camera, but need more zooming and light gathering in the early evening.
