Dark Penguin
Well-known member
- Messages
- 113
- Reaction score
- 18
When working with telescopes, it's easy to calculate the theoretical magnification as the focal length of the objective divided by the focal length (FL) of the eyepiece, but the diameter of the objective doesn't enter into the equation at all. You could theoretically obtain 600x using two-inch objective lens/mirror combined with the correct ocular, but the resulting image would be near to useless given its limited light-gathering capability.
With the zoom lens I have now, the shortest FL and widest aperture available are 70 and f/4.5 respectively. I think I've mentioned elsewhere how gratified I was to discover that with this setup I can actually get some nice images of the night sky, with much fainter stars being resolved than if I use my other lens at 18mm and f/3.5. For example, here's one I took of Delphinus last night with the 70mm lens, single frame only and with a waxing gibbous moon, yet! (Post-processed as usual in Photoshop to improve contrast and add diffraction spikes):
The above image has been cropped down from its original 4000x6000 pixel size.
Suppose I were to buy another 70mm lens, only a wider one that would permit an aperture as wide as, say, f/2.5. So now I should be getting a lot more light on my sensor with each shot, but would the apparent magnification stay the same? Using the new lens, if I took the exact same shot under the same conditions, and cropped it exactly as I did the above, would Delphinus have the same size in the image? Assuming that any recent Nikon or Nikon-compatible lens will fit onto my crop-format D5600, is there any limit to how much lens my camera can use?
I probably wouldn't buy another 70mm lens; I'd want something different from what I have now. But I'm definitely looking for more aperture without having to go down to extremely short FLs, though I'll be looking into those types of lenses as well, eventually.
