Okay 1:1 and past FF models.
Please explain what 1:1 is as it relates to sensor size. You said in another post that is isn't "FF" (i.e. 35mm format, 24x36mm), but now you seem to be saying it is.
FF models with the F mount have all failed to be the "all around"
capability camera's they would need to be to survive and exist such
as the D1 and D2 series. The Kodak you speak of is the 14N and you
can't get a new one anymore. While great in some aspects, it had
definite "edge of lens circle" issues and very limited high speed
application such as almost all of the Nikon D series models have.
The Kodak lacked microlenses, which loses about 2 stops of speed. It also used a very inexpensive (for 35mm format) sensor that had a number of other... challenges. Kodak folded up shop just before the Canon 5D was introduced.
Edge of circle issues can happen if the lens in question has a short exit pupil distance. Digital doesn't work too well with that. Please note that this has nothing to do with any particular mount, it's a lens vs. sensor issue. You can design the sensor to be more friendly to such lenses, and you can design lenses to be more friendly to sensors, or some combination of both.
The Leica DMR and M8, a few medium format cameras/backs, and perhaps (if you believe the rumors) the Canon 1Ds mk2 use offset microlenses, which allows use of lenses with shorter exit pupils (basically, many wide-angle lenses). Other lenses (most wide-angle) have been designed or re-designed for longer exit pupil distance, the Canon 16-35mm mk2 being just one of many examples.
The Contax N was a similar situation in that it apparently produced
excellent studio images where everything is controlled for
lighting, but failed miserably for everything else.
The Contax N has the largest mount of any 35mm SLR. But as I wrote above, it isn't the mount, it's the lenses vs the sensor. In the case of Contax, it was apparently the sensor and the electronics that were to blame.
I believe (which is not worth much to you here realizing my
technology challenged state), that the F mount diameter is too
small and the reason Nikon may come out with the 1:1 size.
So please tell me, what is 1:1 size?
Seen in a fortune cookie:
Fear is the darkroom where negatives are developed
