It's interesting people need an answer, whenI have PS CS4 & Bridge. I've read the dope sheets on lightroom, but
I'd like to hear from my fellow Nikon owners what you think of
lightroom and why.
Based on you comments, I took a closer look at how the cache is created. It seems that, if you are processing raw files, two caches are generated. The first is the "relatively" small lightroom cache and the Camera Raw cache.I think that LR cache size may not be typical. You're at 3.4
megs/image, which is about ten times the average. I'm guessing your
cache is "fresh" and contains a bunch of 1:1 previews, in addition to
the "standard" 1440 pixel previews.
I agree, but "workflow" seems somehow obvious and trivial if you haven't used it. I mean: Bridge does workflow. When I first tried Lightroom I couldn't see the advantage over Bridge & Photoshop. It was only when I'd practised it on a few sessions of hundreds of photos - then I found out just how fast and effective it is.It's interesting people need an answer, when
it's quite obvious - LR is a true workflow tool.
Photoshop is a glorified pixel-manipulation tool.
You totally miss the value of Bridge CS4 - if you have the CS4 system, then Lightroom is probably not necessary at all. In fact, for processing one or two thousand images from a shoot, Bridge / ACR is at least as fast overall as using lightroom. I can often process a large shoot of 1500 images with necessary image editing entirely in Bridge / ACR and not need photoshop for any editing process at all. Essentially all features of Lightroom are in Bridge (but not all).Expanding what you say a little:
A lot of PP on a few photos: use Photoshop.
A lot of photos (hundreds or more) then you probably haven't time for
so much PP, and Lightroom really comes into its own. And maybe use
Photoshop on a few.
Well, I have CS3 not CS4, and I hear CS4 Bridge is somewhat improved. My comments relate to CS3 Bridge, which (in my opinion) does not match the workflow capabilities of Lightroom.You totally miss the value of Bridge CS4 - if you have the CS4
As I say, not (in my circumstances) for CS3.In fact, for processing one or two thousand images from a shoot, Bridge / ACR
I agree with you: it really comes down to preference. I used to use CS3 Bridge/ACR for the workflow for which I now use Lightroom. I find Lightroom faster, but I could use Bridge.I can often process
I would have to try CS4 to know whether I agree with that!In other words, if you have CS4, then Lighroom is unnecessary.
It wasn't meant to be true clone or heal, but to remove dust spots or a quick adjustment or 2. If you have significant editing to do, export it to a PS or PSE.to say the least. The circle thing is really not well implemented.
I'll take larger cache sizes if it allows me to switch between RAW files and have functions/adjustments be processed quicker! That's a no brainer!One thing I noticed is that Lightroom generates very large Cache
files if you shoot raw and select the "standard" cache options. For
example, one directory I have with 1450 raw images requires a cache
size of 5 GB whereas the same cache structure on Bridge is 600 MB -
this is almost 1/10 the cache space.
Unless you get a 64 bit edition then 4 gigs is the maximum amount of
RAM that can be used by your windows machine (I don't know about
Mac). That's 1 gig for the OS and 3 gigs for any single
application. Windows 32 only knows about the 4 gigs. >
I was speaking of a Quad Core running Vista when I referred to 6 Gigs of Ram. I currently run the max (4 Gigs) on my single core 3 Ghz machine, which is running XP.
CNX2 may have slightly better IQ, but the clunky way it was written
and the frustrating complexity of it became a dealbreaker for me.
I'm not a PP wizard but don't some adjustments effect the overall image, and yes will "screw up" the other adjustments if not done in proper order? I start with what I believe is called "global" adjustments first then get down to "local" adjustments.As if that weren't enough, if I make even one adjustment, say in WB,
or D-Lighting or anything else, instead of adding to the progressive
improvement of the image with each new adjustment, it screws up the
other adjustments. Nullify would be a more accurate word. Well, I can
do a USM adjustment and that won't affect all the others, but many
other things will. The sheer # of adjustment panes and the fact that
every one of those panes gets reset to the program's default
absolutely kills my workflow & productivity! A program that was
supposed to help speed up my work, compared to previous versions
instead slowed it down to a glacial pace. It now takes about 10X
longer to work on each pic. That's unacceptable! I called Nikon Tech
Support and the guy agreed that they had heard similar complaints and
that it can be frustrating, but at this time, no updates are
available to remedy the complaint of it resetting all adjustment
panes back to default.
You do need to read the help file and look at a few of the excellent NX2 tutorials on the net.CNX2 may have slightly better IQ, but the clunky way it was written
There are 2 things I like about NX2. Well, 3. The faster
magnification, faster noise reduction and the clone tool. All those
are significant improvements. I do like those.
Now what I absolutely hate and what negates all speed improvements of
those features above is that every time you open a new image, the
adjustment tool panes on the right immediately revert back to the
default tool selection. NC 4+ let you keep all the panes on right
exactly where they were, where I want them.
With NX2 I have to go searching and point & clicking them back in
place EVERY time I open a new pic.
Try this only if you have a fast processor.As if that weren't enough, if I make even one adjustment, say in WB,
other things will.
You can easily Copy and Paste adjustments from one open image to another.The sheer # of adjustment panes and the fact that
You probably got the correct yet misleading answers, sure there is no new update BUT NX2 already does all these things you just need to get familiar with NX2 and forget how Capture 4 worked.That's unacceptable! I called Nikon Tech
--And, no, batch processing won't help either if each of those pics are
not similar to the others in brightness, WB, contrast, etc.
The speed / smoothness of Bridge 4 is as good as Lightroom overall.I'll take larger cache sizes if it allows me to switch between RAW
no brainer!
A large cache size is only a problem if you're worried about cache
size or on a slow computer with limited resources.
Cool. What's interesting is that your observations differ so radically from mine that I had some trouble figuring out why, for a moment. I'm pretty sure everything you're objecting to is a side effect of using the "Embedded & Sidecar" previews (AKA "the Devil's own preview")...Based on you comments, I took a closer look at how the cache isI think that LR cache size may not be typical. You're at 3.4
created.
Not as far as I can determine.It seems that, if you are processing raw files, two caches
are generated.
I can't see what Lightroom has to do with a "Camera Raw cache" at all...The first is the "relatively" small lightroom cache
Quite true.The lightroom cache size seems to be dependent upon how you do your
file import and which options you select for cache image size.
The "standard" option generates a JPEG in the "prophoto RGB" color space. You can select the size (1024, 1440, 1680, or 2048 pixels on the long edge) and the quality (low, medium, or high).The
"standard" option seems to generate a minimal cache where as other
options such as "Embedded & sidecar" produce a very large cache.
"Embedded & sidecar" produced the smallest initial cache, but hte greatest cache growth, because it generates 1:1 previews constantly. However, if you have Lightroom set to discard 1:1 previews after a certain time, this growth will taper off on longterm LR use. You're not giving it a chance.The
Bridge cache is sort of "medium sized" - not as large as the cache
created with "embedded & sidecar" but larger than that created by
lightroom's "standard".
I can't locate that cache.In addition, when processing the raw files, Lightroom creates a
Camera Raw cache.
You're naming an awful lot of caches. I think what you're seeing is the normal addition of a 1:1 image to the LR cache.which grows in size as images are processed. For
example, if you do a "Develop", the images are added to the Raw
cache.
A slideshow will use a "standard" preview if it is available and if you're slideshow is at a lower resolution than a standard preview. If I slideshow to our Canon projector, the 1440 resolution is enough (the projector is 1440 by 900). Since you're using "embedded & sidecar" you don't have the "standard" preview at all, so your Lightroom generates a 1:1 for every image.It also seems as though the "Slideshow" can add to this cache
but I cannot figure out exactly how or when.
I don't know. I think reuse is regulated only on the basis of time.The raw cache can
become very large. However, I am sure that this is limited to a
maximum value
I don't think LR and CS/Bridge/ACR share any caches.and the space is reused as needed. This makes sense
considering that processing with CS4 and/or Bridge and Camera Raw
also uses this cache space for it's nominal processing.
If I regenerate the standard previews for one of the higher resolutions (1680 or 2048) then any image in portrait orientation will show from the standard preview, but horizontal images will still need 1:1 previews generated to get them to 2560.Thus Lightroom can have small or large caches depending upon which
options you use to create the cache.
Maybe so (I'm not that familiar with B4) but I can say that you've got your LR set to be very slow and awkward.The speed / smoothness of Bridge 4 is as good as Lightroom overall.I'll take larger cache sizes if it allows me to switch between RAW
no brainer!
So you maintain, based on a small LR experiment with really horrible settings.My present Bridge cache contains 410,000 images and is 150GB in size.
I have not tried to use Lightroom for this process since Bridge 4
does virtually everything I need.
Thus, if you have CS4, there is no advantage to use Lightroom.
ACR is used by lightroom to decode the raw files. You can see how this is created by lightroom in the Raw Cache file. The location can be found in Bridge by looking at "edit / Camera raw settings" menu item. On a windows system, this is inNot as far as I can determine.It seems that, if you are processing raw files, two caches
are generated.
