What's wrong? I said that there will always be noise in the signal
in the analog forn. That noise will be made up of SHOT and THERMAL
noise. But it's not the noise alone that is significant, it's the
noise in relation to the signal, the signal-to-noise ratio (SNR).
That SNR will determine how sensitive (Max ISO) you can use the
sensor at. Smaller microelectronics are allowing larger photo
diodes on the same small chips to get better SNRs as is now being
developed at the U. of Rochester.
Smaller electronics will not allow better SNR. It will allow
slightly better dynamic range. The reason you don't get better SNR
is that the micro lenses already gather the light from the area
over the non-sensitive area of the chip and focus it onto the
sensitive area. Therefore, the micro-lens design (and size,
obviously) is the driver for how many photons are collected, not
the area of the sensing element.
What's wrong about that? Or don't you understand the process? Read
about that Rochester chip I referred you to and you may get a
better understanding of what I said.
http://www.dpreview.com/news/0512/05121201new_chips.asp
That approach will have no real effect on noise at all. There are
several cleaver approaches for getting better dynamic range
including my personal favorite (at this time) of re-using the cell
once it's full. None of these are yet available but, if they do
become available, then dynamic range can be effectively infinite
changing the story back to just a matter of noise. In that case,
the number of pixels is largely irrelevant. In fact, you might be
able to get better noise performance with more pixels of a smaller
size than with fewing larger pixels. Like I said above, the
dynamic range is the problem.
