Jay Turberville
Yep. F/2 is f/2. Just like 50mm is 50mm. And just like focal length, f-ratios on a smaller formats give different results in final prints of the same size. And the smaller sensor size makes larger apertures more important if you intend to keep noise and DoF capabilities equivalent.Hmmm... Then why is one f2 and the other f2.8?F/2.0 on 4/3 system is not brigher than 2.8 on full frame 135mm.
Nah.. nice try but I think you're wrong! F2 is F2 is F2 whatever
the format! Unless someone wants to educate me on why he's right?
So f/2 is f/2. But if you are comparing different formats, you need to figure out the equivalencies of their effects. Just like you have to for focal length.
Yep. F/2 lets in more intense light than f/2.8. But (assuming sensors with the same photosite count) if you want the same total number of photons per photosite (aka pixel) so that shutter speed and S/N will be equivalent, then the smaller sensor needs the extra speed - just to maintain parity. It also needs the faster f-ratio it to maintain parity with shallow DoF.Which lets in more light for the size of the format! f2 is brighterWhat Olympus did with their lens in
comparison to the sensor size is indeed larger because the image
area is 1/4 of the full frame lens,
than f2.8!
Jay Turberville
http://www.jayandwanda.com
