I honestly don't understand why so many people want to go FF.
I do. There is no fast ultra-wide zomms for APS-C, better high ISO performance, higher resolution, better use of the best lenses.
WA is of course one factor but WA lenses are
cheap compared to the long tele.
True but I don't buy the crop bennefit of smaller pixels on smaller sensors. Just use a teleconverter instead or buy a 'slower' (worse F-value) longer lens and increase ISO.
No fast ultra-wide zooms availible for APS-C.
And remember that on a 1.6x camera
we only use the BEST part of the lenses, the center.
I don't agree on this one either. You get more detail out of the lenses when using bigger formats.
Of all the
comparisons I have seen I find it difficult to see any difference
in IQ between the 5D and the 20/30D.
I think the 5D should have been atleast 16MP or 8MP ISO12800 capable. Now they choosed a solution where the 5D have slightly higher resolution and slightly better 'per pixel' high ISO performance, so I can understand that it's hard to see that it's better sometimes when you don't get both bennefits.
Personally I would prefer higher resolution.
Bigger pixels on the sensor
should mean higher S/N ratio. But it s signifiant for most amateurs?
And by the way, why stop at 24x36, why not bigger format?
Th reason 36x24mm is an important sixe is that it's the biggest most convinient format. Fast primes, fast zoom with IS, cheap great zooms (Canon 70-200/F4L etc).
Medium format and, even worse, big format is better but MUCH more expensive and much more trublesome to use.
(who
startet calling medium-format FF? Canon?)
Does Canon say that FF is medium format ?
Bottom line: I think I'll stick to the 1.6X bodies.
Me too. For the price and evolution advantages. But bigger sensor would be better if I could afford them...
( I don't know the reason for this rant, maybe I just have to
convince myself )
As the rest of us ?
I stick with APS-C since I can't afford to swap a 36x24mm sensor based DSLR every 3 years. Since I don't want to pay much for the 1D body (wheather sealing, AF-performance etc) I think I get better image quality for te money with APS-C vs 36x24mm.
For instance now the 400D probably have better or same pure image quality as the 1Ds (11MP). Resolution and high ISO performance is probably the same.
So changing APS-C bodies more often will be better economicly as long as the FF cameras cost as much as the 5D cost.
I will definitely swap to 36x24mm if a high resolution modell is released, optimized for ISO100 with maybe some noise, or price is lowered.
Henrik
