The Sage Knows
All I can do is shake my head in dismayIt's all luck friend!
To add to this; I NEVER white balance. I ALWAYS, ALWAYS shoot in auto white balance.
Robert
Either way you're still thinking in terms of light referenced to your key whereas I'm thinking in terms of light referenced from my ambient or the lowest part of my dynamic range. We may both get to the same point, it's just a matter of where we start from.Actually I think in terms of how many stops difference there is between the intensity of the main + fill incident on the subject and the intensity of the light falling into the shadows. I can translate those to ratios if I want to in order to communicate with a traditional portrait photographer who thinks in terms of 2:1 ,3:1, etc.
The answer to your question is a fill placed on the same side as the key doesn't fill in the shadows on the opposite side. That's the whole point. You don't have to fill in every single shadow, and some left alone can create quite dramatic effects. Fill doesn't have to come from the axis. It could be cross lit, side lit, top lit, even back lit. Some photographers use reflectors quite often to great effect. I prefer not to because I like the level of control I get with lights better. My favorite tool for on axis fill is my orbis ring which I use quite often.Perhaps I wasn’t clear about what I considered “the subject”. I’m not talking about a flat backdrop. I’m asking about a three dimensional person with a light to their left (or right)as the main and a second light along the camera axis as the fill. Just like your video example. How again can a “fill” placed along the same axis as the main light possibly fill in the shadows created as the main light gets blocked by Bruce’s nose and visible from the camera position. The answer is - it can’t. Therefore, you need another light along the camera axis to fill in the shadows. Some try to do it with a reflector but ideally, the fill should come from the same position as the camera.
I'm not talking about using the picture on the LCD. I'm talking about using the histogram on the LCD.That’s also what most all photographers with a meter including myself also do. It takes the place of a Polaroid previously used to check such things. It's the use of the LCD to base exposure settings from that I called crude and can't take the place of a lightmeter - properly used.
See above. And re-reference the Sekonic quote.You must be using some pretty luminescent paper as the contrast of a typical LCD can range from 500:1 to 1000:1 while glossy print paper has a tonal range of 100:1. Ever try to soft proof in Photoshop using the paper profile and with the simulate paper button checked. Adobe's Jeff Schewe calls this the "Make my picture look like crap" button. And that's because a print that reflects light usually has less dynamic range than a backlit display.
With one significant difference. Notice he speaks of his fill as his very first light, which strongly implies that he's setting that up first before the key, which is exactly how I do it. You're doing the reverse. Again, nothing wrong with that. It's just a different approach.He actually refers to the “fill” exactly the way I do.Here's a guy that seems to speak English as his first language, and creates images for the cover of Time. He uses the term in the exact same way I do:
http://www.youtube.com/watch?v=cqkqO_mmG7g
He's not trying to define fill. He's explaining the effect he gets from on axis fill. For simplicity sake he speaks of "another shadow", when the reality is it's the same shadow created by the blocked key, it just gives the appearance of coming from another direction, which you most certainly do not want generally.The Sage Knows wrote:
Wait back up to (1:14) – did he just say that a “light” can create a “shadow”
Someone needs to revoke his Time Magazine credentials for speaking such heresy!
I tend not to think in terms of "supposed to be". Ties me down too much and kills creativity. I like filling on axis too because it's relatively foolproof and easy, but I'm not afraid to try something different.2:28 “and certainly the ring is from the front and it fills in the shadows .”
So he describes fill pretty much word for word the way I did. And he places it at the camera axis as it is supposed to be.
How do you know exactly where the highlights and shadows are if you don't have a modeling light?Correct. That's why I will pick a spot (cheek), and with the flat diffuser parallel with that spot, I measure the highlight...
Now you're back to the histogram again. We're starting to just go around in circles.I'm not talking about using the picture on the LCD. I'm talking about using the histogram on the LCD.
My Elinchroms have modeling lights proportional to the strobe power. That's how.How do you know exactly where the highlights and shadows are if you don't have a modeling light?Correct. That's why I will pick a spot (cheek), and with the flat diffuser parallel with that spot, I measure the highlight...
Some of the latest Incident Flashmeters CAN be set to assume particular dynamic range sensitivity in the recording media in use, so this potential shortcoming has been circumvented, apparently. I forget which models they are, right now, but they're presumably top-end Sekonics...[??]Re> I don't understand how a device seeing how much light there is could know if it's going to blow out highlights or underexpose shadows.
It doesn't.
Not exactly. Cameras do have TTL flash metering and control built in as well. These work fine most of the time but they can be fooled by the same things that can fool the camera's ambient light meter.If you are talking about using flash, a cameras light meter can only measure ambient light.
I've wondered that myself. What I prefer is to have both sides state their case based on factual information rather than personal pride.I find it funny that first, someone would tell another how to shoot, and two why their way is better than another.
I am familiar with Gregory Heisel, the photographer in the YouTube video. If there is no useful information that can be obtained from an incident light meter, you have to wonder then what he is doing using using one here:Notice how he says, "about two stops". He doesn't care about ratios. He's describing how he's building the shot from the bottom end of his contrast to the top. Furthermore, since Bruce's face is constantly changing gradient, I don't know what useful information an incident light meter would give you.
--I've wondered that myself. What I prefer is to have both sides state their case based on factual information rather than personal pride.I find it funny that first, someone would tell another how to shoot, and two why their way is better than another.
