DavidMillier
I think those classical philosophers' ideas of perfect mathematical ratios and so on have lived on as a guide to composition far past their usefulness. Anything goes as long as it suits the subject to my mind.
I do think we need to make a clear distinction between two different arguments, though.
Argument #1 is about the final output shape. To me any output shape is fine if it suits the image.
Argument #2 is not about output shape but about the utility of in-camera aspect ratios (especially switchable ones) as a technical aid to composition. It sounds to me like you can look through any aspect ratio viewfinder and mentally crop what you see through it to how you guess the final image should look like. I can't do that easily and I benefit from switchable aspect ratios as a visualisation/composing aid.
At least I did until I realised the extreme utility of the square format and the unique way that it both simplifies the process of composition by drawing attention to the relationship between subject elements and the frame edges; and the way it also enables compositional choices because it makes very tiny composition changes have a big effect.
