Ben_Egbert
99% of all my shots will only be seen on a PC. I never shoot portrait mode for that reason. The aspect ratio should match the monitor. Ideally, the 24-inch monitor I use at work is better than the 21-inch I use at home, because it is closer to the 35MM format.
Ben
Ben
In which case you have to crop every single picture. horribleThe medium format world has done well with square image capture:
1) You never have to tilt the camera sideways, just crop as needed.
workflow...
Unless you're printing square pictures, a square format wastes a2) A rectangle wastes more useable lens image projection than a square
lot more...
Try this. Take a lens with a 100mm image circle. It fits:
Square, 70.7mm x 70.7mm. Total area 5000mm2.
Rectangle (4:3), 80mm x 60mm. Total 4800mm2, an incredible 4% less
than the square.
Rectangle (3:2), 83.2mm x 55.5mm. Total area 4615mm2, a whopping
7.7% less than the square.
Now, lets try to do something really radical, and make a print. How
bout an 11x14? We crop like this...
Square, 70.7mm x 55.6mm. Total area 3927mm2.
Rectangle (4:3), 76.4mm x 60mm. Total 4582mm2, 16.7% more than the
square.
Rectangle (3:2), 83.2 x 55.5mm. Total area 4615mm2. That's the same
as the square.
No. You have to do something really radical, like visualizing andBut this won't work for consumer digicams, because you can't just
plug it in and print it without sitting down and thinking about how
you want to crop the picture.
planning the picture, instead. Like the master photographers, who
almost always used the rectangular view camera.
Well, you've just seen that the rectangular pictures utilize atThat leaves DSLRs, most of which already suffer from sensors that
don't utilize enough of the image projected by the existing lens.
least as much (and usually more) of the image circle of the lens.
Very few people. Look at film cameras, the square MF makersSo if fullf rame DSLRs are to become the digital version of
mainstream medium format, there would be a place for square
sensors. Who would want one?
(Hasselblad and Rollei) both went belly up. The rectangular 645,
6x7 and 6x9 makers survived.
The snapshot "shoot it square, crop later" philosophy works when
you're trying to maximize the productivity of a high paid
photographer, by throwing low paid "croppers" at the final product.
Its great for the wedding and portrait mills. Not so good when
there isn't a low paid "sweat shop" cleaning up after you.
But there's a reason every art or craft emphasizes the quality of
the input of a process. Why we teach visualization as the first
step in photography. Why we have sayings like:
Measure twice, cut once.
Garbage in, garbage out
You can't inspect quality into a product.
Ciao!
Joe
http://www.swissarmyfork.com
