Which camera?
If you want to do wild life you definitely need a lot of zoom,
unless your planning on petting them or something. As for
megipixels Ive been told (though I dont personally know) that
megipixel is only important if you want large pictures. Are you
interested in photos to be framed or published, that might effect
how much megipixel you need. Also unless your doing photo as art
the contents of the picture are what is most important.
I would say that the quality of the lens is most important of all. Everything else depends on it. As for megapixels, I'd say that 5 mp is more than enough for most people who are, lets face facts, mostly viewing on screen or else printing to A5 (about 8¼" by about 6") and sometimes, but not too often, printing to A4 size (about 8¼" by about 11¾"). For everyday use a good 3 or 4 mp camera will approach the quality of the 5 mps ones. Just look at the picture I mentioned earlierto see what I mean - it's from a 2 mp camera. The link is in the second of my two adjacent posts.
What are white balance and compression? How important are they and
what do they effect?
Pay attention at the back - there may be questions on this later... ;-)
We'll start with WB; your brain and eyes are very good at post production processing and so most scenes that you see appear to you to be "shot" in identical lighting. But really you brain is adjusting what you see and standardising it. So you usually always see white and white. Mechanical things will see the yellowish-red light from (say) a normal light bulb as yellowish-red and white things will appear yellowish-red and other colours will be distorted too. WB adjusts the colours and shifts the balance slightly to make white look white and so on. Most people and camera are set to "Auto-WB" and do it automatically. In some cameras you can over ride the auto-settings and set the colour temperature (as it is called) to whatever you like - though it is best to set it to whatever your colour temperature meter tells you... Also, on some cameras you can wave a bit of white paper (Kleenex tissues are a good example) in front of the lens and capture that as the standard white, but only for that shot and under that lighting. (E-10 and E-20 owners use Pringle lids for this but this is a very specialised art - almost witchcraft... )
Compression: a 5 megapixel picture, for example, will generate a file of about 14 MB size and this can be compressed by various processes to a much smaller file but, this is the important bit, it does it by getting rid of the subtleties; the more it removes the more the file is compressed. The most popular compression device is the JPEG* file (or jpg) but there are many others.
When you view the file it is uncompressed but will not be as subtle nor as detailed. If you edit the file and then save it, it will be compressed again and more will be lost. So a lot of people are happy to save their pictures as TIFF's, which are about full sized ('though some can be compressed). Other save the pictures as the RAW data from the CCD but this needs a "plug-in" (usually) to get it into a managable version for your viewer and editor. (Asking about RAW usually generates a huge post on this forum - why not do a search on it and TIFF and JPEG?)
In some cameras you have a wide choice: these are usually serious (means expensive here) cameras and you might have a choice of saving pictures are RAW data, TIFF's and a variety of JPEG's depending on the compression rate you use. (I use 1:2·7 and have no complaints but I seldom go beyond A3 size: experiment if unsure.)
Aside: jpeg's and others also/sometimes give you a little thumbnail and then the EXIF data and then the picture. These can (and do) get lost in some editors. Use the brilliant freeware "EXIF Image Viewer" to see it, BTW.
Some cameras give you no choice and so you get compression ratios of 1:18 or so - it all depends. High compression can limit the print size and the editing that is possible. So it pays to get the picture right before squeezing the shutter release. OK?
It is also why you should save the original picture and copy to CD-R later and another copy for viewing and editing.
Regards, David
  • Joint Photographic Expert Group
Hi,
thank you for this expound, it is very helpfull for me, but I still feel confused.Ok I'll devote some pixs for a better quality, but I can not devote a manual control of a white balance(Panasonic Lumix DMC-FZ1), couse the automatic mode is not enough good!My conclusion is that if I'm on budget, I must certanly secrifisy a pics quality, cause of WB or noise or problems when shottong in low light, am I wrong?I really like the lenses of Panasonic Lumix DMC-FZ1, but it has all that problems, so I have been looking Panasonic Lumix DMC-FZ10, Cannon S1,Nikon Coolpix 5700 and Oly &765-770.Only this cameras are not too far from my price range(I will try to purchase in Philipins to take better prise-I have a friend there)Maybe the best lens are panasonic, but I have prejudice about Panasonic and digital cameras-what do you think?Tell me frankly, if you were me, what you gonna have?
I'm really lost among that vast variety of cameras, facilities and problems.Tell me please, what can I devote to get the best for that money(£200-250)?
Thank you in advance!
Best regards!
Hi,
I don't know how to advise you simply because I have little experience of these cameras but I can say that low light shooting is not much of a problem for most people simpoly because they then use the flash. And very few shots are low light anyway.
As for the FZ1 - I can't see anything wrong with it when reading the owners reviews and adding a pinch of salt from time to time. The problem with owner's reviews is that a lot of people forget that photography is not as easy as they think and the camera gets the blame. (Like buying a small and economical car and then complaining that it won't hold six people and their luggage and do 200 mph!
Have you seen this post:
http://forums.dpreview.com/forums/read.asp?forum=1018&message=8579716
He shows a picture and gives a link where there are others that can be downloaded and printed.
Anyway, and I hope you don't mind me saying this, going for a long zoom limits your choice a lot. If you were to look for a more convemtional camera and then (when you could afford it) a long zoom for wildlife; life might be simpler. For example, the Olympus C-4000Z is one of the cheapest excellent cameras going but hasn't got that magic zoom fitted. But for 99% of all photographers it would be perfect. And the C-4000Z isn't the only one.
Good luck, David
Hi,
money(£200-250)?
Best regards!
Hi,
I will ask only for your opinion of these cameras: http://www50.shopping.com/xSBS-Digital_Cameras~PG-1~NCP-6~PRDLT-20249244-20253167-20258146-20700855-20983318-21253683
I think I can go for OlyC4000Z , but the problem is,if considering your advice, for pixs 4Mp is too much.And the bateries are AA, wich is not very nice.About Fz1 it is tempty as well, but if I can get beter price for fz10, it would be worthy!?Tell me what do you thing when you comparing that cameras?
At this point it ought to be your decision. I can only comment on one and that's the Olympus, which a friend has and which seems OK - though I can't see the point of a long zoom.
I think I can go for OlyC4000Z , but the problem is, if considering
No: not too much because 3 or 4 are OK and, if the price is much the same, go for whatever you like.
... And the bateries are AA, wich
is not very nice.
AA's are OK in my experience, and cheap, and readily available everywhere. Get a good charger and Ni-Mh's (ie Maha charger and Sony, Panasonic, Energizer AA's etc in about 2,000 mAh capacity).
... About Fz1 it is tempty as well, but if I can get
All I know about these is what others on the forum say. My ideal would be the Olympus C-4000Z chosen on its specification, price and then confirmed by the reviews. Don't forget that I don't use long zooms and think you need specialised lenses for specialised jobs. (Like dental work or the Nikon f2·8 6mm and so on.)
Anytime, but I doubt if I've helped much!
Regards, David
