So it seems that what I'm taking away from all this is that the Read Noise graph on Photons to Photos is misleading at best and wrong at worst.
That would be woefully incorrect.
See this post from over the weekend and the "Input-referred Read Noise" for documented evidence that read noise historically gets lower as ISO increases and that dual-gain sensors edit the same low read noise that works be generated at ISO 6400+ at ISOs as low as the 400 to 800 range.
https://www.dpreview.com/forums/post/68343633
Bill,
Just looking at the Read Noise graph on Photons to Photos, the graph shows that read noise, the Y-axis, increases as the ISO, the X-axis, increases. Is that not what it's showing?
An upward slope in the Read Noise in DNs plot can still reflect reducing or constant input-referred read noise. DNs are post-gain values. As ISO increases, the analog signal is amplified before being digitized. So even if the actual noise at the sensor (in electrons) stays the same, the amplified noise appears larger in DNs.
The input-referred read noise chart plots read noise vs ISO. The plot for the 1DX clearly shows read noise decreasing as ISO increases. This was standard performance for digital cameras prior to dual-gain sensor tech coming widely into use.
The input-referred read noise plot for a dual-gain sensor camera typically shows read noise abruptly improving (getting lower) at some ISO in the 400 to 800 range and staying low up through ISO 6400+. This is the benefit of a dual-gain sensor the same low read noise that was historically available at high ISOs is now available at much lower ISOs.
The shadow improvement chart plots photographic dynamic range in the shadows (the effects of read noise) vs ISO. The plots for the same cameras will show the same performance described above in a different way.
The 1DX profile shows PDR in the shadows gradually improving as ISO increases. This is the result of gradually reducing read noise as ISO increases. The reduction of read noise as ISO increases can be inferred from this plot.
The plot for a dual-gain camera will show an abrupt improvement to DR in the shadows at a given ISO and then constant DR up through much higher ISOs. Again, the constant read noise level can be inferred from the constant PDR in the shadows.
The read noise in DNs chart isn't your best option for understanding the read noise produced by a camera at specific ISOs (input-referred read noise), of the effects of read noise on the camera's performance (PDR shadow improvement). The DN charts don't contradict the performance documented in the other two. They also don't translate as directly if used as an indicator of read noise.
The photographic dynamic range (PDR) charts plots PDR vs ISO. This chart indicates the combined effects of shot noise and read noise. Shot noise is naturally occurring randomness in light and is the predominant type of noise we see in photos. It's determined by the total light energy used to make a photo, which is why this plot shows a steady decline - along with a bump in performance at a camera's dual-gain point - as ISO increases.
ISO is the setting we use to manage image lightness. As exposure decreases, ISO is typically increased to compensate. This the correlation between increasing ISO and reduction in the cameras dynamic range. It's the increased shot noise that's the culprit. ISO is thec canary in the coal mine. It's an indicator that a camera is become starved for light.
The line trends upward as you increase the ISO. I don't know how it could be seen any other way.
I'm only asking about what that specific graph shows.
So if then as you said, the chart to use to see read noise performance vs ISO is the input-referred read noise chart, what is the purpose of the Read Noise chart that I've been looking at?
The "Read noise in DNs" chart isn't the one to use to see read noise output or the effects of read noise on DR in the shadows. The "Input-referred Read Noise" chart directly plots read noise. The "PDR Shadow Improvement" chart can be used to determine how invariant a camera is and to infer read noise performance. These are the charts to use a references.
