What's best way to down sample an image?
Brian
MI, US
I've been editing my Italy pictures and would like to start putting them on the web, but I need to reduce them down to 640x480.
There are a bunch of difernet routines availible for resampling. Which do you find produces the sharpest images for reducing the size?
difernet = different
availible = available.
size?
I use Infranview and it seems to work OK. I usually use a small touch of Unsharpen after I resize. Done in PSE.
"6 monts ago I cudnt spell enginear now I are one" LOL
Jeff S
UZI 21OO, C2OOO, B3OO, A2OO
WB9ZPO
Pbase Supporter
The sad thing is that as an engineer I tend to generate more paper work than most other professions. Type 20 emails/day, reports, orders, design guides, etc.
I knew it was either an engineer or a
programmar...progromer...programar... argh
Irfanview ( http://www.irfanview.com ) is a GRRRREAT (misspelled on
purpose :-> ) freeware program. Will do batch resizing among a
thousand other things.
Clicker
These are three types that PS5.5 uses. I'm not sure what method irfanview uses. I did do a batch resize with irfanview and all of the pictures need some sharpenning. I was just wondering if there is a better way.
Jeff S
WB9ZPO
Pbase Supporter
See the post 'photoshop creates jaggy edges ???' from a few days ago for a discussion of why Photoshop is not the best tool for doing this.
Infranview has several selections. If you want to do all the sizeing and sharping at one time take a look at this program
http://www.mediachance.com/dce/index.html
They have a 30 Day trial and the retail version is $35. It is easy to use and does many things all user choice and settings.
Hope this helps.
Jeff S
WB9ZPO
Pbase Supporter
Hahah i'm an engineer too (just graduated from Systems Engineering Program here in Canada)
anyways the best algorithm for resampling for general purposes is a bi-cubic resampling.
There are other algorithms that software can use but depending on the images you can get extremely poor results.
a great program that you can try all the different options, as well as creating thumbnails, auto sharpening, colour balancing is called Altasoft EyeBatch.
it batch processes images. Its great for resizing 600 images in 4 clicks.
Hope this helps,
Mike
Clicker
What kind of algorithm does it use for down sampling?
Altasoft EyeBatch.
clicks.
Hope this helps,
Mike
Clicker
I'm pretty sure you can select between a few of them! (like 5 or 6)
my photoshop 7.0 does bi-linear and bi-cubic and nearest neighbour.
Altasoft EyeBatch.
clicks.
Hope this helps,
Mike
Clicker
Hi Brian,
I found that Photoshop standard resampling are not working well..i prefer Lanczos and its available in infranview. Infraview can be downloaded for free on the web, but i don't have the link.
Maybe someone has it?
size?
Daniella
http://www.pbase.com/zylen
C700 FORUM: http://www.c700uz.com
