What should I have done?
Jarrell Conley
USA, GA, US
My one week old D100 seems to have a very good built in flash and I've been trying to improve my fill flash technique with it. I'm satisfied with the below photo... somewhat, the part I'm not happy about is the blown hilites in the hair ...
I was using aperture p mode with the lens at around f/5.6 and I believe that is where my mistake was, I should've dropped the f/stop down to f/11 or f/16 to properly expose the hair and let the flash fill in the shadows properly. Then, I wouldn't have gotten the background exposed right. But, as always.. I had time for a shot or two and then my victim had to leave.
Anyway, is my thinking correct on this?
Thanks,
Jarrell
My Personal Favorites
http://www.pbase.com/jarrell/personal_favorites&page=1
Based on my limited experience, I'm not sure the D100 has enough dynamic range to properly expose the hair without losing detail in the shadows.
I'm not sure you could have done a better job at all. Also going from 5.6 to 11 the background might not have looked as pleasing.
I'm sure others that know much more then I do will weigh in.
Keep shooting my friend. I'll have a few "suprises" to post soon. :)
Kind Regards,
David
Thanks,
Jarrell
I think what is far more important is to tell that lady to go find a different hairdresser, then worry about blowing out highlights!
Thanks,
Jarrell
Yeah, but if you stil want to control DOF and keep the blurred backgroud (@5.6 or wider). You might try spot metering, or CW metering. The thing that you don't want is overexposures, like your blown highlights (virtually unfixable). So, it you spot metered on the highlights, you MAY have gotten a slight underexposed face (fixable).
One of the easiest things to do is moved to a shaded area when the sun is beaming.
I am still learning myself, so take my comments lightly!
PLL
Thanks,
Jarrell
Its tough to get perfect exposures in situations like this with digital. I think your d100 images you have posted so far have been terrific, keep it up.
Also, gavin, lets leave the rude remarks to the poeple over in the Canon forum..no need for that here. Lets be nice:)
Steve
sun is beaming.
PLL
Thanks,
Jarrell
The Range of a D-100 or any other 6 megapixel DSLR is not as wide a medium format digital or negative film... But we can over come that.
I'll list several ways that I know
1. Shoot the flash manually so that the stop difference between the highlights and shaded areas are closer. Don't forget to stop down on the camera. You will probably underexpose the background slightly.
2. spot meter the highlights and bring back the shadows post-production... the new shadow highlight adjustment in Photoshop CS will do a great job of this. Its also a new feature from Kodak and in Nikon Capture 4.
3. Use transulent material such as a transulent reflector over your subject. This does require an assistant, however, it is the best way to achieve what you are looking for.
Personaly I think the image you shot is very nice and the highlights do not bother me, however, I understand you want to be more in control and I welcome your pursuit of technical mastery.
best of luck
H
Thanks,
Jarrell
Exposure compensation -0,7 EV
Flash compensation +0'3 EV
Use the Rear curtain Sync mode in D-TTL with the fill flash (inboard flash I assume).
From there, you will lower the exposure a little bit avoiding some blown out highlights. You can also vary the Exp compensation accordingly. It is quite hard to comment without being there but I would still give it a try.
The blown highlights are not very distracting BTW. It is a very good shot.
Thanks,
Jarrell
Yves P.
PBASE Supporter
Some pictures I like:
http://www.pbase.com/yp8/root
the shadows.
Kind Regards,
David
good shot.
Thanks,
Jarrell
Yves P.
PBASE Supporter
that very constructive comment.
Jarrell
slightly.
best of luck
H
The woman was sitting on a porch so it would've been easy to move her forward a few feet. Problem solved.
Thanks,
Jarrell
sun is beaming.
PLL
This setting is completely new to me (the only fill-in flash setting I know is from Thom's book) .... Can't wait to give this a try :)
Happy holidays :)
good shot.
Thanks,
Jarrell
Yves P.
PBASE Supporter
Regit Young, FCAS Member, PBase Supporter
42 species caught, 808 species to go ...
'Seeing and interpreting are entirely personal processes' - Steve Parish
http://www.pbase.com/regit
Steve
different flash modes on this camera. Thank you for those tips, I'll try them out!
Jarrell
good shot.
working with this camera any little tip is appreciated. I've not used the rear curtain sync mode yet but that's next.
Thank you,
Jarrell
good shot.
never use rear sync and don't really know what it is for!!!
BTW, I don't think the highlight is a problem in this pic.
Thank you,
Jarrell
Yves,
I know you're a big fan of rear curtain sync, but what difference would it have made in this situation? Rear curtain sync also enables slow sync, but that wouldn't be an issue here, since the picture is no doubt bumping against the FASTEST sync speed. I don't see how popping the flash at the end of the exposure instead of at the beginning would make a difference however.
Duncan C
good shot.
Thanks,
Jarrell
Yves P.
PBASE Supporter
dpreview and PBase supporter.
http://www.pbase.com/duncanc
A question if you don't mind... say if the ambient light is low and the resulting speed is slow, would rear curtain sync makes a different given that the subject is static? Thank you.
I apologies if I'm missing the obvious.
Duncan C
good shot.
Thanks,
Jarrell
Yves P.
PBASE Supporter
