Well, being as this is a speculative subject, I think we'll leave it at that.
That Photoshop and Apertura are stagnated is not hypothetical. FOSS software will clean their clock if they don't get their act together soon.
We don't really know what would happen, we can only hope for the best. History does not leave me optimistic though.
Query; what is the world's most installed OS across all computing devices at this point? Hint; it was created out of open standards and is as open as they can become.
Open standards always win in the end. It may take a while, and digital computers are very young, but the writing is on the wall.
Buggy, or simply lack of resource to develop?
Lack of resources means lack of commitment means lack of alternatives. Exactly what I expect will change with a lower barrier of entry.
But why the option? is it really necessary?
Yes, linear is necessary. It's to work around the issue with incompatible sensor arrays.
Ok, that to me suggests that DNG is not capable of being the standardised format we need it to be. A 'workaround' for some sensor arrays is not compatibility if it's not able to access all the data that those arrays have available (which is shown on the Apple bulletin I provided the link to).
The reason for this is that the less than half a dozen cameras affected are - less than half a dozen. If another sensor layout becomes viable and gains traction that's when the spec needs to be extended to be able to handle it.
And even so, we're talking a grand total of four sensor arrays in commercial existence today, two of which need special treatment (and are used in less that four cameras each). It's not something which hurts the point of the standard.
Of course we are distracting from the original point here, which was whether it's worth converting existing Raw files to DNG. I think that it is probably isn't, as there's currently no guarantee that all the information available will be usable.
There is no guarantee that all the information available in a raw file will be usable no matter what. The difference is very slight. Either way, standardizing on DNG will endure all the information available will be usable.It's worth fighting for.
The whole point of a standard is to eliminate problems opening files, if there are problems opening files, then the standard has failed. Of course I agree that Aperture should be keeping up, but again, if it can open one 'version' of a 'standard' file, and not another, then that is not a 'standardized' file.
Again, how can a spec protect against bugs, sloppiness and bad programming? Apple are not following the spec; how is that the fault of the spec?
Because the spec does not allow for all the sensors available properly. That surely is the whole point of it, no?
No, that's not the point of the spec, the point of the spec is to standardize file formats on cameras, meaning it should work for 99-% of cameras (and it does) and be ready to extend to the ones that make sense to extend it to (and it is) and handle the odd cases well (which it does with linear mode), and either way, incorrectly implementing a spec is not the fault of the spec. Especially when others with ostensibly fewer resources manage to get it right.
Hmm, we would possibly get more choices - if anyone though it adding any more to the ones already available.
We might, but the most important thing is that lowering barrier to entry puts some fire to the couches the present market leaders are relaxing in.
My own recent searches has already found there are more choices for Raw conversion than I thought there were. I've been trying out darktable and RawTherapee, just to see if they could really be replacements for the commercial options. They do a good job for sure, but IMHO, no, they're not ready for that, but for someone starting out, wanting a cheap way to edit and organise Raw images, yeah, they are a good start.
And the main reason they aren't more than that is the high barrier of entry.
But, they do show that having more choices does not mean better choices.
It means the market leaders feel the heat from competition, and are forced to improve. I'm sure the LR and Aperture marketing people are following Darktable and RawTherapee closely.
It might if it's allowed to mature into a proper standard, and one that isn't controlled by a large corporate.
This is the issue. The sole advantage of DNG is that it exists and works now. There is no need to start over. A new standard would have to start from scratch and make all the mistakes DNG has done all over again.
FWIW, I do agree that DNG as a concept is very much a good thing, but only for new cameras that support it natively, and we can trust that all the data is universally available in all software. Personally I'm not as optimistic as you seem to be.
Currently, I can't see any point in converting if you already have software that already processes your existing Raw files. Why bother adding workload?
At this point in time, the reason is pretty much none. If DNG becomes a standard, there is definitely a reason to convert, as it opens the door to using any conversion software one likes.
Actually, your point is that one standard has flawed implementations. Your examples show a lack of a single standard, and multiple splintered standards with multiple implementations causing problems.
Which is exactly how it is with raw today, and exactly how it would not be with a standard raw format.
Thus, your point is the exact opposite of what would be expected would DNG gain traction as a mainstream common format.
Even PDF has odd anomalies that sometimes cause apps to trip up though.
Which is still a lot better than pretty much anything around except JPG, and that is pretty darn good work for a standard encompassing as much as PDF does.
And yeah, no program is bug free, so sometimes PDF's will cause problems. I'd question reality if this was not the case, and no software ecosystem will ever be perfect -not the raw conversion we have now, and not a DNG based ecosystem - but some are better than others, and it's easy to be better than the raw mess we have on our hands now.
That depends. I do the same with Microsoft too, and I'm not suffering too badly for it
As do I, to the extent I am able due to work. But throwing away an open standard (which Microsoft have 0 of) just because you'd rather play into the hands of those pushing proprietary formats and pay extra for the effort and development time spent working around imposed limitations is not helping either you, the camera manufacturer or the raw conversion software developers.
Adobe have screwed us for too long, particularly here in the UK where their pricing policies have shown they are profiteering in an unreasonable manner. They do upgrades that cost more than full versions, and their software is about as buggy as anyone elses. How do we trust them with DNG?
The same way we trust them with PDF. We ensure it's an open standard.
ImageMagick, XnView, Xv, x2y, Pixillion, etc., etc. ... there's tons.
Name one with a standard Mac OS GUI!
That is an incredibly narrow view. The point isn't the application or GUI, that is trivial to add (and there are several native OSX wrappers around conversion libraries). The point is having the functionality available for the front end applications to use.
Many websites, for example, use ImageMagick to serve up images. If they can easily throw up color corrected raw images from any camera, present or future, how is that not a win for every web surfer out there?
If any web developer currently locked into PNG and JPG can just add not only a DNG, but a DNG with embedded lossless correction to any place in a web site, how is that not a tremendous step forward, allowing high end photography to take a leap forward?
With the advent of proper color spaces in browsers and the rise of 10 bit color in screens and cards, this would mean that images posted today could be rendered for today's screens now, and for larger gamut as it becomes available, all without any intervention or software updates.
It would mean that you could put up a gallery site today, pump raw images to it and have them displayed to the viewer at the best available gamut - and when you get a new camera, you just keep uploading, never worrying about software versions.
It's a different paradigm. A completely different way of thinking. Thinking "oh, it's like today, only the files are named DNG" is completely missing the implications. This has the possibility to be huge.
Going forward, for sure. Going back to what I said earlier, we have two arguments here.
1. whether converting existing documents to DNG is worthwhile.
If DNG becomes a future standard it will be.
2. whether DNG worthwhile as a future standard format.
It is to such an extent it is almost impossible to convey the implications.
Whatever the next new technology is, who knows, but history has shown this to happen in the past.
And when new technology arises it is because it can stand on the shoulders of giants and leverage existing technology. The present raw mire does nothing to help innovation and works hard to hinder it.
Some have, Olympus already switched their software to free. I don't know about others though.
Unfortunately Olympus are a small player. It would take Canikon to make waves on this matter.
Yes, but it's all speculation. We can hope, but I don't trust any of them to play by the rules.
That is the beauty of open standards. What do you think would happen if a camera maker would start churning out non-standard JPG which only a few applications can handle? They're get torn apart in the press, and lose sales like mad.
If DNG was standard, the same would apply to that.
There is no better weapon for consumer protection than open standards, and no worse enemy than proprietary standards.
Jesper
