As someone who is considering buying a Light Track 2, is the polar scope that is sold with it not accurate enough? What is the periodic error with it as compared to the PM, or give me some indication of the difference in accuracy.
how do you define accuracy? the polar scope is accurate enough to have like a 90% chance to get 5 min and more with 135mm, not 6 min with 400mm. with the PM you gain reliabillty depending on your exp.time and focal length. PE? It is neglectable, around 1 arcsec. see the fred about it
Stefan, I bought the Lightrack II and Polemaster and have been using it for the past three nights. I am curious which wedge you use to achieve such a fine alignment? I have a Manfrotto 405 geared head which I thought had very fine movements but I have great difficulty getting the green cross to align with the red circle. The best I've done so far is around 1 minute at 300 mm.
I have
this one, bought it i an package. Put up to 18kg on top (in the pic below), but had two securityscrews beneath. The trick is to find the right amount of loosening or tightening the adjustmentscrews. too tight makes it difficult to finetune in height. I was afraid that the load could drop, so the extra screws, as can be seen here:
secure 1 min with 300mm is pretty good. 3 to 6 should be possible
Best regards
_____
Stefan
