theoverratedphotog
The TT350 works well as a trigger, the main issue is the usability side. Triggers like the XPro are very easy to change settings on so that's the main difference I see. When you change settings constantly, the usability becomes a big issue, particularly if you have multiple lights.Thanks for this wonderful guide, which I'm saving as I get into flash photography more. I've had the tt350s for about a year and use it occasionally, but would now like to grow into more off-flash, but light weight photography. I'm considering the Godox V1 as a complement, and to keep things light for travel/on-the-go usage, I would appreciate input on how effective the tt350s as an on-camera trigger and low light-source would be with the V1 as an off camera option on a stand or handheld. I realize a trigger would probably be useful, so perhaps I'd add that as well, but for a two light, minimalist outdoor, on-the-go option, would these two alone work? I have just a mini hotshoe soft box for the tt350s now. Any other light diffusers for fitting in a single bag you'd recommend? Thanks again.
From a diffuser perspective, godox do a nice 40cm square softbox that comes with a speedlight bracket. It's small enough for use with the TT350 indoors, but outdoors it will underpowered. If you can afford it, I'd recommend an AD200. Not much bigger than the V1 and far more powerful and that means you can use it outdoors with the sun.
