Using a dummy battery.... timeout problems
rothwells
Forum Enthusiast
Richmond, US
We are a small church that is using 3 A7III cameras with HDMI->SDI adapters to do services.
We have been using a PD power bank plugged into the cameras to continuously power the cameras. It works pretty well with the exception that the camera's internal battery (which is required) uses a little more power than the USB-C input gives. This is normal.
The issue is that even when the camera is turned off the internal battery still discharges slightly. The camera people at the church aren't exactly broadcast engineers so (right or wrong) the camera internal batteries are sometimes not charged each week after a service. Of course, eventually, this means that sometimes on Sunday morning, the camera's battery will be nearly dead.. When that happens no amount of USB-C input will power the camera.
Yes, the best solution is to simply take the camera batteries out of the camera each week and put them in the charger, then put them back in the camera each week. Again... easier said than done, depending on the volunteers.
So, I bought V-Mount batteries with dummy batteries. They would GREAT -- except for one teeny, tiny problem..... the camera doesn't KNOW it's a dummy battery. It thinks its just a battery and the power saver kicks in... really bad in the middle of a church service. It looks like the most you can set the power save to is 30 minutes.... Am I missing something -- like another setting somewhere that tells it to NEVER power save? What is the point of a dummy battery if you still have to "tickle" the camera to prevent it from going to sleep?
Thanks for any help. Yes... Ideally we'd have spent $200,000 and done the video system right but when given a budget of only $15,000 for everything I had to punt.
Power Save is not supposed to kick in when recording movies. If your cameras are going into Power Save while shooting movies you should open a support case with Sony.
But, an easy work around might be to enable the IR remote:
MENU →
(Setup) → [IR Remote Ctrl] → desired setting.
When enabled, the camera will never go into Power Save.
A7R4a with SEL2470Z, 55Z, and a number of adapted lenses (Canon FD, Minolta AF, Canon EF, Leica, Nikon...); A7R converted to IR.
ahhh Sorry I left out a small detail We are not recording anything We are just taking live video out of the camera, sending it out HDMI
MENU →
MENU →
OK. Well, enabling IR remote should do what you want.
MENU →
Thank you. I’ll try that!
MENU →
Thank you. It worked! Technically I understand why it works... camera has to remain on to watch for IR remote commands. What frustrates me is, even on Sony's web site specifically discussing using dummy batteries, it says NOTHING about turning on that feature to make sure the camera doesn't shut down <eye roll>.
Very much appreciate the help!
MENU →
Great! Yeah, usually this comes up because someone is wondering why their camera WON'T go into power save.
It would make a lot more sense if Sony had a "Never" option above the 30 minutes for power save.
MENU →
I just looked on my personal a1…. It does have a “none” option, along with 10sec, 1min, 5, min & 30 min. Sure would have been nice to have had that on the a7III. Would have saved me a ton of time being that was the first place I looked.
MENU →
Are your dummy batteries first-party (Sony branded) or third-party?
It seems like the circuitry in first-party dummies explicitly identifies itself as being a dummy battery, but many third-party batteries seem to have recycled a lithium BMS to the point where the coulomb counter is still running and attempting to estimate remaining capacity.
Context is key. If I have quoted someone else's post when replying, please do not reply to something I say without reading text that I have quoted, and understanding the reason the quote function exists.
